Hi all ,
Saw a guy had a bride replica seat at the Dyno day that just passed in his red M3 and it looked really good , so im considering getting it soon.
http://www.justjap.c...&cat=282&page=1
Has anyone tried fitting one of these in theyre 32 / what sort of modifications am I looking at doing / is there any welding to be done??
I phoned justjap and they said even if i get the skyline rail i will still need to modify it to fit the actual seat.. so ill just use the rail alredy on the car.
If anyone can help me put it in , i will buy you allot of beer :)
Thanks
John
https://www.sau.com.au/forums/topic/359789-bride-copy-seat-in-32-gtr/
I've got a similar one in my R34.
All I had to do was to get a Recaro rail (thanks to JDMPWR), it bolted straight onto the seat and since the rails was made for R34, it bolted straight onto my car.
No problems at all :)
Those universal rails that comes with aftermarket seats will never fit your car without any mods.
But to be honest, these seats are awesome, hugs the shit outta you around corners, but if your car was a daily, I'd reconsider lol and think about Recaros instead....
It's SOOOOO bad to get in and out of, especially you don't wanna just flop onto the seat everytime you get in and out as you try to avoid the bolster tears lol
Oh and to be precise, those are Recaro SR3 rails to suit R34.
As the SR3's mounting holes are in the exact same position as the Bride style.
They can be found 2nd hand for anywhere between $50-200 lol
Even a skinny person like me, I have to support myself by pushing up against the door jam to get in and out. And it sucks when I park in a very tight carpark with a car next to me :(
But when I'm turning corners in it, it is AWESOME, I don't even sway one bit lol
Is your seat from holford Motors or jj charlie?
Damn they look so good man! Thanks allot for the info , ill look into getting those rails for my 32.
Would 34 rails have the same bolt patter to go on a 32 floor??
just buy a cheap generic low mount rail and drill the holes to suit. heaps cheaper than buying a genuine rail
Bought it from a dude in Frankston, brand new lol. It owns the Drift Blades :P
It's heaps awesome man, for the price you pay and the comfort you get, unbeatable. If you are around my area, you are more than welcome to come see it in real life and have a sit in it lol.
And no, R34s have different rails to R32,R33s.
It's not just as easy as drilling a few holes...
Those universial rails won't bolt onto the car properly without mods, let alone bolting onto the seat. And you wouldn't wanna be modding the rails, as things could go bad during an accident.
And drilling holes in universial rails to fit the seat might not work, as the rail's mounting brackets might be too far or too close apart, which won't line up with the seat.
The amount you spend on a cheap unversial rail ($50-100) and the time you spend on modding and the risk you take on modding, I'd rather pay extra $50-100 to get proper rails.
Having said that, having a replica seat can also be a risk during an accident lol
the only difference between a universal rail and say a r34 specific one is the shape of the mounting plates essentially.
i dont see how drilling your own holes is any different to using the existing ones. its still a thick bit of steel bolted to the floor no matter how you do it.
Well depending on the universial rails I guess, but I think some of the times, you will find that the mounting brackets are sitting so far from the mounting holes that you will need to modify the bracket, eg cutting and rewelding or welding an extra bit of metal wit hole to line up with the car.
lol there is no way in hell that the universal 'rail' (which is in-fact just a sliding mechanism, no base) will fit into a skyline without some welding.
John the jjr rail will work, you may need to drill your own holes in the jjr rail to mount to seat to, that is it. But they mount the seat pretty high.
And you can't use the rail that is already on the car, as you will need to re-weld/cut/hack it up to mount it to the bride style seat.
The ///M runs one of these (to fit e36), I run one in my car as well.
http://www.nzkw.com/index.php?main_page=product_info&cPath=104_93_96_130&products_id=250
Attach the slider that comes with the seat onto that base, nice a low. easy.
Buy the seat and then buy the genuine bride rail for that seat and it will fit in the r32 no worries. Ive had both the copy and genuine brides run on the same rail in my r32 gtr gtst and r33 gtst no worries. This was with the bride gias seat similar to what you have...No cutting or welding requried.
Man, my asian hips struggles a little to fit in it and I weigh 55kg lol
They are heaps tight
Also, instead of getting from JustJap. Hollford Motors (think that's what it's called) in Melb sells the same seat but with bride logo on it lol
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
