Hi all ,
Saw a guy had a bride replica seat at the Dyno day that just passed in his red M3 and it looked really good , so im considering getting it soon.
http://www.justjap.c...&cat=282&page=1
Has anyone tried fitting one of these in theyre 32 / what sort of modifications am I looking at doing / is there any welding to be done??
I phoned justjap and they said even if i get the skyline rail i will still need to modify it to fit the actual seat.. so ill just use the rail alredy on the car.
If anyone can help me put it in , i will buy you allot of beer :)
Thanks
John
https://www.sau.com.au/forums/topic/359789-bride-copy-seat-in-32-gtr/
I've got a similar one in my R34.
All I had to do was to get a Recaro rail (thanks to JDMPWR), it bolted straight onto the seat and since the rails was made for R34, it bolted straight onto my car.
No problems at all :)
Those universal rails that comes with aftermarket seats will never fit your car without any mods.
But to be honest, these seats are awesome, hugs the shit outta you around corners, but if your car was a daily, I'd reconsider lol and think about Recaros instead....
It's SOOOOO bad to get in and out of, especially you don't wanna just flop onto the seat everytime you get in and out as you try to avoid the bolster tears lol
Oh and to be precise, those are Recaro SR3 rails to suit R34.
As the SR3's mounting holes are in the exact same position as the Bride style.
They can be found 2nd hand for anywhere between $50-200 lol
Even a skinny person like me, I have to support myself by pushing up against the door jam to get in and out. And it sucks when I park in a very tight carpark with a car next to me :(
But when I'm turning corners in it, it is AWESOME, I don't even sway one bit lol
Is your seat from holford Motors or jj charlie?
Damn they look so good man! Thanks allot for the info , ill look into getting those rails for my 32.
Would 34 rails have the same bolt patter to go on a 32 floor??
just buy a cheap generic low mount rail and drill the holes to suit. heaps cheaper than buying a genuine rail
Bought it from a dude in Frankston, brand new lol. It owns the Drift Blades :P
It's heaps awesome man, for the price you pay and the comfort you get, unbeatable. If you are around my area, you are more than welcome to come see it in real life and have a sit in it lol.
And no, R34s have different rails to R32,R33s.
It's not just as easy as drilling a few holes...
Those universial rails won't bolt onto the car properly without mods, let alone bolting onto the seat. And you wouldn't wanna be modding the rails, as things could go bad during an accident.
And drilling holes in universial rails to fit the seat might not work, as the rail's mounting brackets might be too far or too close apart, which won't line up with the seat.
The amount you spend on a cheap unversial rail ($50-100) and the time you spend on modding and the risk you take on modding, I'd rather pay extra $50-100 to get proper rails.
Having said that, having a replica seat can also be a risk during an accident lol
the only difference between a universal rail and say a r34 specific one is the shape of the mounting plates essentially.
i dont see how drilling your own holes is any different to using the existing ones. its still a thick bit of steel bolted to the floor no matter how you do it.
Well depending on the universial rails I guess, but I think some of the times, you will find that the mounting brackets are sitting so far from the mounting holes that you will need to modify the bracket, eg cutting and rewelding or welding an extra bit of metal wit hole to line up with the car.
lol there is no way in hell that the universal 'rail' (which is in-fact just a sliding mechanism, no base) will fit into a skyline without some welding.
John the jjr rail will work, you may need to drill your own holes in the jjr rail to mount to seat to, that is it. But they mount the seat pretty high.
And you can't use the rail that is already on the car, as you will need to re-weld/cut/hack it up to mount it to the bride style seat.
The ///M runs one of these (to fit e36), I run one in my car as well.
http://www.nzkw.com/index.php?main_page=product_info&cPath=104_93_96_130&products_id=250
Attach the slider that comes with the seat onto that base, nice a low. easy.
Buy the seat and then buy the genuine bride rail for that seat and it will fit in the r32 no worries. Ive had both the copy and genuine brides run on the same rail in my r32 gtr gtst and r33 gtst no worries. This was with the bride gias seat similar to what you have...No cutting or welding requried.
Man, my asian hips struggles a little to fit in it and I weigh 55kg lol
They are heaps tight
Also, instead of getting from JustJap. Hollford Motors (think that's what it's called) in Melb sells the same seat but with bride logo on it lol
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
