R32 Gtr stuff I have lying around:
Brembo front brakes $1,100
Includes calipers,new pads about 50km old, Apexi?(has Harrod stamped into them)two peice rotors lots of meat and no lipping, brake lines and all bolts to install on your beast
R32 Gtr front seats $700
These are quite possibly the best R32 Gtr seats I have seen. There is practicaly no wear- even the pictures make them worse than they actually are. If we weren't selling Jennas Gtr these would be going straight in!
Nismo 260km/h dash $280
3.5 inch turbo back exhaust $500
Includes massive cat, stainless and in awesome condition.
Have been told it is a Veilside exhaust but cannot confirm at this stage.... stay tuned
HKS front pipe- tuned length (a bit rusty)
17X9 Gtr offset Rays lightweight rims (very light) $800
Two with minor gutter rash
245/45/17 Yokohama DNA E-spec rubber with 90% plus tread
Need a wash but will do that when I pull them off
R32 Gtr Tein coilovers in good condition $700
Will get photos up tomorrow night once off the car
All parts located in the lower Blue Mountains Sydney
Pick up prefered but also happy to post
Pete
0448468884
i have had a few people ask so i googled that stuff
the rotors are this brand "harrod"
http://www.uniqueautosports.com/harrod_brake_upgrade_kits.htm
the brakes are painted gold at the rear but no marking on them so who knows what they are but they are 99% new
pete
0448468884
brembo's sold!
nismo 260km/h dash $280
3 guage cluster $40
aircon $40
nismo gear knob $60
17X9 gtr offset rays lightweight rims (very light) $800
two with minor gutter rash
245/45/17 yoki DNA E-spec rubber 90% tread
needs a wash but will do that when i pull them off
rear bar $170 includes tail light
tail light 40 each
turbo back exhuast $500 includeds massive cat
velside exhuast?( thats what i was told)
cat back is stainless and in awesome nic (3,5 inches)
front pipe is tunned lenght hks ( seen better days)
r32 gtr front seats $700
these are quite possibly the best r32 gtr seats i have seen, there is no wear even the pictures look more warn out then they actually are, if we wernt sell ing jennas gtr these would be going straight in!
other things available, pick will come as i pull it off ( the car that is)
boot with wing $150
gtr seats (these are perfect) $700
doors $100 each good condition
entrie gtr rear end $800 ( this is the entire rear cradle and everything in it)
gtr motor (still to be tested and compression tested)2k-3k dpending on condition
gear box $600
abs $50
side skirts $100
everything behind the dash including wiring $300
rear wiring loom $200
centre consol $40
door cards $50
front window $100
rear window $100
rear quater windows $50 each
full seatbelt setup $100
brake master cylinder $40
clutch master and slave sylinder $100
steering collum $100 included key locks
rear seat $80
parcel shelf $40
attessa pumps $50
UPDATE
nismo 260km/h dash $260
aircon $40
tail light 40 each
boot with wing $150
gtr motor 2k-3k dpending on condition
gear box $600
abs $50
side skirts $100
front window $100
rear window $100
full seatbelt setup $20 each
steering collum $50
attessa pumps $50
gtr front brakes with rotors lines and calipers $300
Black R32 Gtr front guards 100
Update:
Sold:
- Brembos
- Seats
Still Available:
- Nismo 260km/h dash $280
- Tein Suspension $700
- Fujitsubo Giken 3.5 inch turbo back exhaust $500
- Tuned length front pipes $
- Volk 17x9 +19 offset rims $650
Two rims have some gutter rash but overall good condition with almost new Yokohama rubber
Pete
0448468884
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
