I got it downloaded and set it as it said, but then I lost all writing. I set it back to anything with Western again and now the boxes that were in Japanese symbols show nothing at all. Crap.
The version I downloaded was 2.0 and Win7 should be 5.01. I think that is my problem with the MS Gothic not working. Sure as heck not paying $129 for a silly font.
My car also doesn't come up in fast.
HCR32 XXXXXX
Also had a mates S13 that doesn't work either. Every other car apart from those two have worked for me though.
if you were to go to google, and search 'ms gothic japanese', and then hit enter, you might find the second link helpful :)
It doesn't seem to do much to my fast pages but
My second link was Wikipedia? Looked through it, but didn't see anything helpful to my issue. Is that what you were referring to?
Haha sorry. It's on fffonts or something like that
I work at a nissan dealership.
There is a local version and a japanese version.
When doing imports you pretty much ignore the 6u9000 part. Its easier to just use the model number instead
Not the most user friendly catalogue but quite good when uve got the hang of it
PM me if u need help
Edited by n_D
That was the one I used originally and it didn't quite work right. That was the reference to version 2.0 vs the 5.01 that Win7 needs.
  • 3 months later...
I finally got around to re-installing fast on my computer after it crashed, vin numbers won't work??? I have put the MS Gothic font too but theres still heaps of japanese writing? what am I doing wrong here.
your not putting the aus part of the vin in are you? (6U900 or whatever it is) just go ECR33 12345 (as an example)
Otherwise you can press the CD looking icon at the top and choose a model. Just makes it a bit of a pain when you go to look at illustrations as you have to pick the car from all the different options each time
as long as the books (a1, a2 etc) are in the right spot and the program is looking in the right spot you shouldnt have a problem
Sounds like you have used it before so I dont need to explain that the VIN is split into 2 boxes, Trying to think of any other tricks but non really come to mind
Here is what I did and this works in windows 64 bit systems so no messing around with virtual windows setup which is a pain in the ass.
NISSAN FAST 2010 and A1, A2, A3, B1, B2 CDs
This will install on 32-bit and 64-bit systems.
http://depositfiles.com/files/c3dqowelq
(this will be approx. 1GB in size)
Instructions
  • Open the NISSAN_FAST_2010_A1_A2_A3_B1_B2.zip file.
  • Extract/Drag the 'NISSAN' folder to your local disk (E.g. C:\ drive).
  • Navigate to 'C:\NISSAN\FASTPRG\WIN2000\SETUP' and open 'SETUP.EXE'.
  • Click 'Next' a few times and complete the setup.
  • Navigate to 'C:\NISSAN' and open 'Nfset'.
  • Select the 'CD-ROM SETUP' tab and add all CDs from 'C:\NISSAN\CD' (A1, A2, A3, B1, B2) by selecting 'Browse' for each drive number.
  • This step is not necessary. In 'Control Panel' open your 'Fonts' folder. Click on 'Font Settings' and make sure 'Hide fonts based on language settings' is unchecked. While in Nfset, click on the 'ALL' tab and select 'MS Gothic' as the font and script to Japanese
  • Now open 'Nissan Menu' from the Start menu.
Hopefully I've explained this as easy as possible and didn't miss any steps.
Cheers,
Ants
I installed it using this method and way.
You tried the link I posted for the files?
I just installed this last week so I know the files work.
You'll need to download MagicDisc, at least 1 2010 file, install via the setup file (I used windows 2k setup), decompress all the letter files into sub directories of the main FAST directory (i.e. c:\fast\A2), edit the NFS.EXE file to point to the sub directories where you decompressed the files, then start the program.
I didn't do this as mentioned. Edited by MrRx7s3
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
