Have you got the folders with the books in them somewhere in their subfolders (a1, a2 etc)?
You need to go to NFset.exe I think it is and manually select the books. I think there are 8 slots, but theres enough for the JDM books anyway. one book on each line
Once your in NFset you should see the file path line and you can browse to select the folders
Make sure you have all the A's and B's from memory in there (one folder for each line) then try again
Are there folders in the A1, A2 etc or do I just select the whole folder eg A1, A2 as I have done, I'll check over it in the morning when i get on my pc, also if I didn't do the folders correctly would the parts show up if you enter the model manually as that works for me at the moment.
No just need to select the A1 folders etc.
Seems odd. I do recall there were certain vins that didnt work (but I thought these were pretty rare) so maybe try another VIN. Is it possible the R34 VINS being looked for are from later on then the year the books go up to? Say for instance if they are a 1999 copy of the parts books but you are looking for a 2002 model?
no idea just a thought
  • 3 weeks later...
Here is what I did and this works in windows 64 bit systems so no messing around with virtual windows setup which is a pain in the ass.
NISSAN FAST 2010 and A1, A2, A3, B1, B2 CDs
This will install on 32-bit and 64-bit systems.
http://depositfiles.com/files/c3dqowelq
(this will be approx. 1GB in size)
Instructions
  • Open the NISSAN_FAST_2010_A1_A2_A3_B1_B2.zip file.
  • Extract/Drag the 'NISSAN' folder to your local disk (E.g. C:\ drive).
  • Navigate to 'C:\NISSAN\FASTPRG\WIN2000\SETUP' and open 'SETUP.EXE'.
  • Click 'Next' a few times and complete the setup.
  • Navigate to 'C:\NISSAN' and open 'Nfset'.
  • Select the 'CD-ROM SETUP' tab and add all CDs from 'C:\NISSAN\CD' (A1, A2, A3, B1, B2) by selecting 'Browse' for each drive number.
  • This step is not necessary. In 'Control Panel' open your 'Fonts' folder. Click on 'Font Settings' and make sure 'Hide fonts based on language settings' is unchecked. While in Nfset, click on the 'ALL' tab and select 'MS Gothic' as the font and script to Japanese
  • Now open 'Nissan Menu' from the Start menu.
Hopefully I've explained this as easy as possible and didn't miss any steps.
Cheers,
Ants
Hey mate
Is the link in this still good??
Not working for me...?
Cheers
  • 8 months later...
Up top there is an icon, looks like a book i think. Hover over it and it should say p/no search
Press that
Hey man thanks for the reply, yeah I figured that out just before noticed it in another thread lol, and this whole time I was thinking the Nissan I go to are stupid because the part numbers never worked, turns out I haven't been giving them part numbers lol.
  • 6 months later...
Worked for me, only difference is I didn't have MS Gothic so used Courier font and so far it looks fine.
[it took me a while to leave XP....lol but eventually I had to bend to the winds of change so skipped straight to 10]
And if you have issues try downloading early in the morning, only took me 1 1/2 hours [and I'm on a really slow connection]. I did try at night but it kept stopping and was really slow [+8 hrs], so I gave up on that.
  • 1 year later...
Hello peeps,
I have been running FAST for years but I recently got a 2004 model car, and my A1/A2/A3/B1/B2 CD set are only 2001 so it doesn't show up.
I just spent 2 hours downloading and extracting the "2010" version only to find out it too has the 2001 CD's. I am 18 years IT veteran and I know what I'm doing in the config files and I used a new directory for the "2010" files, and changed my Directory Setups to the new directory, but I confirmed this as the files in the new "2010" directory have 2001 dates! The same as my old "CD" directory files!
Can anyone confirm they have a CD set newer that '2001/10', (/Help/Version Info) and if they do, where I can get it from?
BTW, my version says v3.50 and I'm running on Windows 10. I have heard there is a ver 5...Is that true?
11 hours ago, sin- said:
Thanks heaps, awesome, it works...just have to start in the menu each time, and select 'AR' or 'JP' depending on the vehicle.
I think I should have probably uninstalled and removed all the older version first, but it went in 'over the top'. I wanted to install it in a different directory, but it didn't let me and put it in C:\Nissan again, like the old version.
  • 3 years later...
I've found a better font for Windows than MS Gothic, that displays Japanese script well.
MIGU 1M (Monospaced)
I tried MIGU 2M, but 1M, regular, in 11pt size, and ensure you set Script to 'Japanese', not 'Western' (using NFSET utility)
It's much better than MS Gothic, I think.
This is Win10,  1920x1200 screen.
  • 7 months later...
  • 9 months later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
