Hi there,
I have an R33GTST and apart from the high flowed units I was wondering which other 'out of the box' units would fit?
I have not a lot of experience with turbo installation, but what I got so far is that there are quite a few
T3-Flange Units out there.
For example this one:
3076R
This turbo has many options, but the 6 bolt mount for my Nissan is not listed. :(
So in reality how are these Turbos matched to the existing piping?
Would it be an option to get a used turbo elbow and then weld / machine some kind of adapter?
Or are these adapters available somewhere?
Many thanks ...
Edited by Torques
  • Replies 55
Posted Images
The honest easiest way is definitely a highflow, as stated above.
We would have no idea about your options in the UK, yet if you are not after a very specific setup you should just decide how much power you want, or how fast you want to go, then pick your turbo to suit.
For example if you were in aus and wanted sub 300rwkw with as little as hassle as possible you would simply buy a hypergear G2 or G3 turbo for 260 or 300rwkw respectively. Obviously these would net the results and save you alot of cash, spending the VAST amount more would net you the same result with a better outcome overall.
Overall implying drivability, spool etc.
Ideally you would want a forward facing plenum, otherwise the standard pipes get in the way of the 4" intake on the 3076 and it just looks messy in my opinion.
But these guys offer a 6 bolt rear housing :thumbsup:
http://www.horsepowe...IAB2/prod18.htm
Just seen that your in the UK, but there are places that do give the option so there might be one there if you ask around
Yeah I was originally going to get the 3076r with the 6 bolt rear on the stock manifold but I'm glad I went the whole hog in the end with the high mount exhaust manifold and forward facing plenum. It's about a trillion times sexier and didn't cost that much more.
Hello to OZ,
Thanks for the replies ..
I would be very happy with 300RWKW, and fancy fat torque over peak power.
Also I would like quick response (so 12PSI+ @3000rpm).
If I could find a used R34GTT turbine, it would be a good bases to high flow it using
a different turbo cartidge.
Cheers ...
Specifically, 12psi @ 3000rpm with 300rwkw to boot is a tall order.
3000rpm is next to nothing and at those revs with that boost this turbo will still be feeling lethargic. Try to grasp that boost @ rpm wont = power nor response, so planning where you want to hit 12psi is next to useless. What you do want to plan is at what RPM you start making good power.
The general consensus for good response is 200rwkw @ 4000rpm. It is a slightly tall order from a 3076r in a reasonable cost effective setup, you will see most making the 140-180 mark. That sort of power and response can be experienced through a highflow, yet the torque and overall feel of the turbo will suffer.
I think you will keep being referred back to the highflow option more than anything else, yet make sure you pick a builder who has well documented results.
Hello,
Yes ... you are correct, high boost at low RPM and 300kw at the rear is probably asking for too much and maybe not possible with a single turbo.
But 200kw at 4000rpm sounds quite good to me.
And 2500-4500 is the range I use the engine most of the time..
I was told a recore with the 3076 internals would be something to consider.
The thing is that a high flowed turbo is not any cheaper compared to
an off the shelf unit.
Many thanks ...
Edited by Torques
yer but a highflow bolts straight on. off the shelf aftermarket turbos require a fair bit of modifying to fit
I agree its easier being a bolt on, but if you were to get for example, a 3076 with the nissan rear housing, you just need a T3 spacer plate , oil and water lines and some intake pipeing. so there isnt alot in it.
Ive just gone for a highflow because i care more about response, as soon as i get it together and back from the dyno i will put up some charts :thumbsup:
If you get a 3076. Do not get the Nissan 6 bolt housing. It is restrictive and plain garbage. To fit a 3076 with the proper Garrett housing requires:
Spacer plate ( so comp housing doesn't touch manifold)
Extended studs
Lines
Dump pipe
-all this comes with the kit and is not hard to fit up
Only thing you will need to do is get a 4-3 inch reducer and make up a custom intake pipe
It's well worth it
And for response? I'm hitting 18-19psi by 3500 rpm. On the 3076 with .82 rear housing
Extended studs
Lines
Dump pipe
It's well worth it
Is your bottom end stock rb25? Also how is your intake setup? 3" metal pipe with pod and AFM infront of turbo or do you have the AFM in the cooler piping?
Stock bottom ended rb25 mate.
I got the 3 inch intake pipe going to my z32 afm which is connected to my stock airbox with a blitz panel filter. Then have a custom CAI going from the bottom of my airbox to a pod in my front bar
Sounds good man. Metal or silicone leading to your box? Can you PM me some pix?
Sound interesting ... :)
So you need a spacer for the T3 connector and modify the turbo elbow to match the 3076 exhaust side ...
Is the 3076 much wider compared to the standard turbo?
Who is selling this kit?
Some pictures/dyno would be nice.
Cheers ..
Extended studs
Lines
Dump pipe
It's well worth it
Cheers ..
Hey mate. Yea you need a t3 10mm spacer to make it fit. The turbo when next to a stock turbo looms huge.
Sorry don't know what you mean about the elbow? You talking about the bend after the compressor outlet or?
I'll get pics tomorrow but it looks VERY stock under y bonnet
This. :)
I dont know why people say 3076 is laggy. But then, comparing any turbo to a stock RB25 turbo its laggy.
I thoroughly enjoy driving Lithiums 300kw 3076 .82 R33. The extra "lag" actually makes the car quite nice to drive. Your not constantly making boost without trying haha. But if you want it, its not far away!
Plus.. the turbo spool noise is orgasmic. :blush:
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
