shit..
im making 20psi by ~5000rpm..
thats with e85, poncams and stempipe manifold
Wtf??? That's shit as. Way too late for a 3076. I got a stock ported manifold and stock cams (have a cam gear only) and is internally gated.
Just looked at your boost line and looks lazy. What controller you using? Or just off the external gate
  • Replies 55
Posted Images
Hi there,
From what you write about your high-flowed turbo I would buy immediately buy it, since it sounds like lots
of low down grunt and fun :) Who made this unit???
I have this nice boost controller, it has 3 settings .. 'off' 'low' 'high' ... wouldn't that help to tame the unit?
Anyhow, the car is used as anything from grocery getter to daily driver (though not as a commuter)
From time to time for the drag strip, but not on a 'professional basis'
My insurance policy states 'recreational use' and that's the truth ..
I wouldn't want too much downtime with the turbo upgrade, and I have a good mechanic at hand who
does very good work (but only at weekends)
Here in the UK there's is quite some backfround noise with High Flowed Turbos, usually you get no 'hard data' on these.
'They' just state 'stage1' or 'stage2' and that's something I wouldn't buy especially when being quite pricy...
I had a recommendation for a HKS28xx kit .. but that was very pricey ...
Cheers from London,
Andrew
I had a hiflow at 250rwkw and it was sometimes pretty hard to drive. Made heaps of boost and came on hard way too early in the rev range. On wet days if you tried to accelerate in 4th from say 70 to 100km/h you'd get wheel spin all the time. Fun but a real PITA, you couldn't always count on controlling it. Not saying all hiflows are like this, but mine was.
Stopping at uphill sets of traffic lights on wet days - just thinking about it used to make me break out in cold sweats. I'd plan my route to avoid having to go through them.
I went to a 3076 with external gate and WMI at 300rwkw and its a totally better vehicle all round. Good reliable steady progressive power. Transformed the car, made it a damn sight easier to live with. So its not called lag, its called control to me!!!
But buying and installing such a turbo takes more effort and $$$$ than one that bolts up to the std dumps etc. It really depends on your end goals and what you want to do with the car long term. Also - if you buy say a hypergear hiflow as an interim step - how easy would it be to resell later and get your $$$ back when you decide to up size??? Simple things like this can help make your build more progressive and easier on the bank account.
Edited by Torques
Too much boost early in the rev range. WTF? Never heard that before. You should drive a 6L Supercharged V8. That's low down power. You need to learn some right foot control. Throttle isn't an on/off switch.
Hi there,
I still would like to know who made this high flowed unit???
Cheers from London :)
It was hiflowed by GCG in Sydney, not sure if it was a completely std turbo to start with, it came on the car. From memory it went from 50/7? to 56/76 but I could be wrong there, I gave all the paperwork to the person who bought it off me. I also had other mods that allowed the 250rwkw to be made [fmic, pfc, tomei cams, dump, exhaust, hiflow cat, z32, etc etc]. But as I said I didn't like its power delivery, was not as progressive.
The 3076 makes 50kw more power but has a much better power delivery and more of it [in the rev range] where you need it.
If I was you I'd send Stao from Hypergear a PM and get one of his units, only ever heard good things about his product.
Yeah ... I will send him a PM, he seems to have lots of experience and also documents his results well.
There's an inner voice that says 'go high mount, go high mount'. ;) But that would involve too much downtime (but would be quite sexy)
Many thanks ...
Edited by Torques
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
