Hi all,
I have some car parts that are available for sale:
R33 Front GTR Brembo calipers and rotors (with bolts)$1,200 ONO
R33 braided brake lines (new) to suit R33 GTR Brembo fronts and standard R33 S2 rears $150 ONO
R33 S2 Whiteline front and rear sway bars(new)$450 ONO
I am based in Adelaide and would prefer pick up but postage is negotiable at buyers expense.
Send me a PM for more info.
Cheers,
https://www.sau.com.au/forums/topic/359855-r33-parts-for-sale/
  • 3 weeks later...
