What do you guys think.
I have just purchased a 300GT sedan, it has monsoon shields on it. Although they are not very large, I think it would look better with out them.
To me they give it a clutterd look.
They are useful when raining and you can still open the window abit.
If you are only after the look, I agree the car will look better without them.
I will remove them if it's up to me. :)
Edited by VNS 24
Nice looking car man!!
It would look better without them but they do serve a useful purpose, at least for me. When it's raining and the cars full of kids I always like to crack the window a tad.
Also when it's hot and you're parked up you can leave the window down slightly and you can't easily see it. And when you first take off and the interiors about 100 degrees you can have the window down abit, the hot air is exhausted quicker letting the aircon cool you down quicker without outside air being blasted in. They do work well and at least they're thin, but I also think the stag gets away with them better than your V, having a big square butt and all :wub: .
Cobey, notice now the ones on the silver car are nearly black? Factory ones are usually brown...... and also the silver car has been de-chromed....
The reason they look out of place is because they cover the chrome line around the window. Buy a chrome strip overlay to reproduce the chrome line ontop of the shields and it wont look so bad.
I had the same dillema, didnt like the look of them and kept bumping them with my hand in drive thrus....... so tried to remove them and just made a mess of the chromework underneath - that tape has had 10 years to cure!! So I went out and bought some 3M tape and put the things back on. Turns out they are very convenient to have on rainy days, and they stop wind buffeting at higher speeds with windows down.
Unless you are prepared to buy new chromework for your window surrounds, I would leave them. Just wrap them in black vinyl or something to get rid of the brownness.
Edited by Trick V35
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
