Got something pretty cool here - thought you guys would appreciate this more than many. We've made a new connection with the guys from D's Club, the US subsidiary of Option Japan and these guys have just released a very cool E-Mag of the R35 GT-R.
It's 160 pages deep, all in English and also covers the newest 2011/2012 model R35. There's tons of other stuff in there and I reckon it's a proper bargain at $8.90. We're not getting anything from each sale, just advertising fees on the site each month so DL it or not - your choice but we reckon it's worth a look, especially if you own an R35. :yes:
Check it out our review on 7TUNE HERE
You can download it through the links we've set up between D's and 7tune.com :thumbsup:
Here's a few shots...
https://www.sau.com.au/forums/topic/359914-r35-gt-r-complete-file/
Nice!
That is awesome.
I love the Mine's page spread.
I saw this on 7-Tune too.
Are you Adam Zillin?
Yep, that's me mate. Actually debating whether or not to take on ownership of a GT-R myself... driven so many of them over the past few years - most memorable being this bad boy up in Hakone...
Clicketty Clicks
If you own a GT-R, you owe it to yourself to see just how good the AP Racing monoblock upgrade is over the standard setup. No comparison.
Awesome!
I guess if you can afford one then go for it :D
Clicketty Clicks
Link no work...
1 day when I get a R35 GTR, I might find out :thumbsup:
Nice subtle changes, so how does the factory Brembos match up to the AP Racing calipers?
Only problem I have with the R35 is that Nissan charge top shelf Euro prices for a Japanese product.
I know they are trying to step up to that level but still...
True, I guess at the end of the day, it is just seen as a 'Nissan'...
They don't! The standard brakes are good but 400mm of CC material and a mono-block floating caliper make a ton of difference. They're the same brakes they use on the Super GT cars. :thumbsup:
ugh...we just got hit by another 7.1 quake
Fuck!
Hope you and everyone else is ok...
Awesome!
Never enough stopping power, I say.
Fuck!
Awesome!
Yeah, nothing damaged but we've had almost 1000 of these bloody aftershocks for the last month now. Slightly unnerving.
Check this link out - it's like earthquake popcorn... http://www.japanquakemap.com/
And I couldn't agree with you more - I used to think that power was everything but now realize its worthless if you can't stop...:laugh:
Great to hear!
Hah! Same here :D
Overall balance is the key, I say.
You will need stopping power to match the horse power.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
