Buy yourself and r32 RB20 thermostat from Nissan. They are 76deg.
Cheaper upgrade than a nismo one.
I have one in my NEO as the running temp was around 90 deg.
Now it sits on 80deg
Wonder if it's affected your fuel economy .. I only say because I recently had my thermostat replaced - now running rock-solid at 88-92C and my fuel economy seems to have improved. Previously it was sitting lower generally but would also spike higher on 35-40C days stuck in traffic.
Do you have evidence to back up your scaremongering?
I agree that if you're reaching 95deg after a couple of hard jaunts up to 100kmh there is an issue that likely needs to be addressed.
Telling people that reaching 95deg is OMG GOING TO REDUCE THE LIFE OF EVERYTHING THE COOLANT TOUCHES, is scaremongering.
or chemistry :whistling:
I didn't say everything the coolant touches, just almost everything. And I didn't say that magically over 95° will cause damage and under will not. I said every 10° doubles the wear. It's not like running at the designed temp there is no wear because there is still wear! Running 10° hotter doubles that wear. Running 20° hotter means x 4. (Not that the temperature is evenly distributed in the cooling system though)
Anyway....just adding a tid-bit of info for interested parties. new-engine.pdf
Edited by simpletool
Only over a certain temperature though. It doesn't double wear when it is perfectly within it's operating temperature. Running at 95 degrees compared to 85 degrees isn't doubling the wear on everything.
Thats why the NEOs run a higher temp thermostat. The hotter they run the lower the emissons are/ the better the fuel eco is, which is good for the environment but shithouse for performance.
Most modern cars now will run between 90- 100 deg for that very reason.
I find it difficult to believe that because they're running at this higher temperature - and designed to - that they're suddenly causing much much higher rates or wear and going through things like water pumps quicker.
Pulled my water pump out for 100,000km service recently (I have no way of knowing if it was previously replaced, sure) and it looked almost like brand new.
Bubba.....seriously. :/
I've been playing with RB's for a while now dude, and I am yet to see the issues you are stating. I'm not saying they DON'T happen, I'm just saying it's probably not as dire as you are making out.
As I agreed with above, if you're hitting 95deg after a quick blat to 100kmh then yes, you have a problem but it's not going to cause everything to fall apart from pitting and corrosion.
Basically, regular fluid maintenance (which coolant is a part of, and something everybody should be doing) will help everything live a (hopefully) long and uneventful life.
Ignore your fluid changes for several years, and yes, you will likely see a massive deteoriation in cooling system components. The lack of maintenance, even at normal operating temps, is going to do a lot more damage than running it hotter but changing fluids more often.
I only stated that the reason temps are higher now days is puerly to lower emissons.
Spot on.
And conversely, you get rather poor fuel atomisation at lower temps so unless your inlet tracts and combustion chambers have been designed to run at ~60deg, nobody should be using one of those low temp thermostats.
I agree, no need for low temps thermostats.
Look, I never meant that there is some dire problem. Just thought that since we are all driving 10+ year old cars then we should be aware of increasing cooling system corrosion (heater cores for instance). It is also a problem if you don't change coolant.
People can disagree with the science if they want, I was just giving some extra info.
+1 I'd rather go with a genuine thermostat.
chinese parts do not always mean rubbish
your joking right? not there is a need for the op to get a low temp thermostat.
but where do you think most parts come from anyway, its a simple thermostat... most car manufacturers are probably using chinese made parts... its not a precision part
wut?
I already said no need for a low temp thermostat, and I didn't say chinese stuff is shit but as far as chinese made goods go you DO pay for quality. That is the only difference in chinese made goods, from the same factory you can have good or crap stuff, depending on how much you're willing to pay for the quality control. I deal with chinese manufacturers and fabricators a fair bit (albeit for much larger scale stuff) :)
Edited by bubba
Hey all I have just purchased a an r34 sedan car has a 3076r with all supporting mods (fmic, inj, afm etc)
Also has a "heavy duty" radiator.....it has standard top tanks but core looks to be about 40 mm thick (standard is around 15mm)
when driving normaly the temp sit in the middle of the of the factory gauge (my other standard r34 sits in the same place)and the aftermarket gauge which is in the top radiator hose sits about 100 but when I drive it a little bit hard ie full boost a few times up to 100km or so it heats up to about 110 120t is this normal to have quite vast temp changes with such little hard driving or am I being paranoid?
Im only worried because my old silvia had a similar set up but ac was removed and had a thick koyo radiator temps never went above 90 on a 30 degree day no matter how hard I drove it
should I look at getting
transmission cooler
oil cooler
alloy radiator ?
any imput would be apprecated thanks Ben
who tuned the car?
what ecu? do you have a dyno sheet with afr?
might need to be richened up a bit to help keep combustion temps down
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
