i was pretty keen on the aluminium ones.
i like the look of them and seeing as much car is going to fully restored, id like that look under the bonnet.
ive got a 240k radiator in it atm, sime slight mods to get it to fit.
whats the difference with the 280z radiators?
well what i would do is:
get the core measurements from both of them and see if they're roughly the same. cant imagine they'd be too different. i can imagine the alloy one will be thinner.
if they arent too different and you really want the alloy one, just get it anyway and make it fit! be prepared to get a bracket made up, or drill new holes, or use zip-ties lol.
ive got the overall measurements for it, they have them on the website.
im gonna go measure my old blown out c210 radiator i have in the shed. and compare the too.
i cant see how they would be too different.
you got any ideas where i could get a c210 aluminium one?
you'd probably have to get one built. but the plus side is that they'd do all the mounting points for you.
first google search: http://www.alloyradiators.com.au/
they reckon they can make them cheaper than stock so have a go.
i have no knowledge to compare the slant type to any other sorry.
those holes they got might work too (just by looking).
email them and see if you can get the drawings for it so you can check against your car.
yeh but what do you think of the "look" of the slanted top tank.
i thnk its only like that due to the zed cars bonnet comming down on a big slant.
but i think it may look cool under the bonnet anyways??
oh as a fashion thing! i get ya now. i personally like a flat one. but i own a flat one so im biased lol
tell you what man, if you think that radiator is gunna look the beez kneez under your bonnet... then do it! it's your car and you have the creative freedom to do whatever you want with it :)
ill put something in my car that looks cool, as long as it doesnt compromise performance, practicality, or legal infringements (most of the time).
hey was just doing some work on my 210 and i remembered that photo of the one you want to get.
the pipe that comes out of the bottom tank on the alloy one comes out then shoots up on an angle. the standard c210 on just comes straight out and is real short. that might be an issue bud.
yeh man ive already emailed them about that.
although i cant see why i couldnt just "cut it off" before the bend. not to butcher it, but the pipe on the c210 radiator is only about 2 inches long, so im assuming on the 280z one, i could just shorten it before the bend.
and im not sure if i want the slanted one! :(
personally i think a flat top one would look better.
if you cut it off, dont forget you'll be cutting off the flange part too. you'll have to re-weld the flange part on or your hose will slip off... which is a pain in the ass...
another something i noticed: the lower pipe on my 210 comes out and goes around the back of the alternator to underneath it before it faces forward. so yea a bit longer than your 2" for some reason.
Edited by Silent Shadow
ah ok, well my origional radiator isnt like that at all.
its just a "stumpy" ahah.
Few of dads mates are top clas welders so i might get them to run a bead around the tube as a flange.
if thats the way i decide to go.
ive found another one, which is a flat top, for the same price, i emailed them about demenions and they havnt got back to me.
i emailed ARE cooling, got a quote for $1170 for a custom made one.
i might the hose from the motor not from the radiator. mine is a little stumpy too.
well if you can get a flat-top one at the same price and you're happy with it then do that. why pay the extra 800-odd dollars for a custom?? jeesus..
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
