Hey
I recently bought a S2 stagea and for the first time last week had it sitting on 110km/h on the highway and noticed how much wind noise I can here around the bottom of the windscreen at the A pillars. It's the same both sides of the car and quite LOUD. I assume this is where it's coming from. It's 100% not the door seals as I pushed on the window and can clearly hear the wind caused by pushing the glass off the seal. Very shocked to hear this as otherwise it's very quiet in the car with no other noises.
Does anyone else have this problem with their 34 stagea and is there any fixes for it?
Thanks guys
Edited by slippylotion
https://www.sau.com.au/forums/topic/360059-c34-a-pillar-wind-noise/
No weather shields on my car. So these will stop the noise?
Can people with weather shields confirm if they do/don't have wind noise let me know an also if people without weather shield let me know if they do/don't have win noise.
But keep in mind I'm certain it's not coming in via the window seals and it sounds like it's coming from around the front of th A pillars.
Cheers
i have had weather shields off my car, then on, and it has made no significant difference.
i would suggest its the seal around the window. it doesnt take much to catch some air and make a noise. mine was lifted slightly on the drivers side towards the lower edge - i just pushed it back in, and it stopped the noise.
what - with the windows open?
if anything having them on should INCREASE noise.
hence why lexus stopped offering them on their LS400's because they increased in-cabin NVH levels. keeping in mind that car had the lowed drag co-efficient AND lowest in-cabin dB reading of ANY car in production at the time.
but you're entitled to an opinion - just as in my opinion the weather shields look sh1t hot! very JDM. i've sprayed the reverse side of mine with black gloss, and sikaflexed them on so that they're water tight. not only are they now very functional, but they look a million times better.
so thats +1 for noisier WITH. +1 for noisier WITHOUT. and +1 for no differnce at all.......
hmm, some inconsistencies in results! hahahah
but seriously, check your windscreen seals, and your window seals.
do you have a sunroof? make sure its closing properly. if its not fully closed there might be an edge on the rear that catches the wind.
Windscreen seal looks to be fine as are the door glass seals. It has no sunroof. I think it might just be the weird shape of the A pillars that causes it but I find it very hard to believe that Nissan designers would have over looked this.
Im going to change the angle of the bottom of the A pillars with STIFF cardboard and gaffer tape to see if it makes a difference.
wait until you take off your wing mirrors to find that they fitted sponge behind them
great for breeding rust!
yep the sponge behind the mirrors is GREAT for rust... i have to fix my rust now.. only a little on one side and too much on passanger side... :( What is better to put there instead of the sponge?
but anyway about the wind noise i have myself some irritating sound myself in higher speeds on the drivers side, and i have those nice wind/rain shit deflectors fitted on my ride... looks nice atleast.. :)
But maybe a adjustment of the window would solve that?
i got windshields, and they do make it a bit more quiet, only reason for it is because we have the "glass only doors", where as most other cars have an entire door with glass frame, which actually keeps it more airtight, my rubber is a bit squashed and once i adjusted my window, it has a 1mm gap in between window and rubber seal and damn the noise is quite irritating on really long trips. just make sure your window seals up nicely with the rubber.
also a nice fix for all your rust problems, the best fix EVER, zinc plate your main rust spots after getting them fixed. thats why AUDI is the most Rustproof car manufacturer out there. just to let you all know, thats how i get all my major rust spots fixed
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
