That is all true. The point of argument is that as the driver of the car turning right you should reasonably expect a vehicle in the slip lane to be:
1. Turning left
2. Slowing down and merging
None of which the other driver proceeded to do.
1. Turning left
Even the police officer advised point (2) is illegal, you *must* turn left from a left turning lane.
If you look further back on that road, you specifically enter the slip-lane about 20metres back and its clearly marked as left turn only.
I doubt a judge will see it that way, I'm just deciding whether to challenge on principal or not.
Agreed that you are supposed to give way to all on-coming traffic, but I didn't expect someone to be driving through a left-turning slip lane.
It is a poorly designed intersection as the traffic island should sit more forward to prevent someone slipping down the left lane and then merging.
And this is where your issue is going to be.
Expectation does not proceed awareness. You are meant to be aware and observant at all times. I remember it from my "Ps" test actually where they use the example of a country road - driving along and you get a few options
1. looking dead ahead
2. looking all around you for potential dangers/hazards
Obviously it's #2.
Either way it's a shitty situation and just the Police being arseholes really. Something like this shouldn't have occurred, it'll probably be a young constable out to get some brownie points.
I'd say go into court, explain the situation and the magistrate will throw it out quick smart. TBH I personally wouldn't even bother with a lawyer, but that's because I am confident I can explain the situation clearly and concisely. If you are not then you may wish to price up a lawyer (note it won't be cheap).
Magistrates are generally reasonable and quite frankly there's not a person alive (notice I said person, some police aren't people) who would not find this totally unreasonable.
Technically there may be some way you are responsible, but in this case the magistrate will have powers of discretion and so long as what you say is factual and you are polite and concise I'd be amazed if he didn't take one look at it and request the police quit wasting his time.
i would fight it too, its clearly marked as a left turn only and has a solid line before the intersection
they would have to have a split line the whole way down if you were allowed to merge from that lane
seems stupid to have it right at the intersection only... unless its just for the entering and crossing from the opposite side saying its allowed
Thanks for the info.
The chances are slim, but I've decided to challenge it on principal, I'd rather lose in court than accept the fine.
I don't think your chances are as slim as you would think.
It's not unusual for the po-po to throw out fines expecting them to stick even when they know they do not have much of a case. I wouldn't be at all surprised if, now the coppers have to sit down and build a case against you, that they decide to withdraw the charge.
And I would be surprised if the worst case was anything more than the Magistrate handing you the absolute bare minimum possible penalty. I would expect, however, that he dismisses all charges as I think any reasonable person would agree that you were not doing anything wrong. Technically you may have, but this is not an open and shut case and the Magistrate will have room to decide for himself and most Magistrates are reasonable people, and have often been known to place closer scrutiny on the po-po that the civvie. And don't forget, the po-po will have to PROVE that you broke the law, you don't have to prove you didn't, unless the police really have something solid to hit you with.
The courts definitely put a lot more emphasis on police to be spot on with everything. We just had case thrown I was involved with out, for car the we impounded doing 70 over speed limit as the informant signed the wrong date on summons. Simple as that, case withdrawn.
My last one similar to this was a contested fine for number plate (had no reflective paint at all) as prosecutor advised me to drop matter as Magistrate would only see it under bright lights in court and give them benefit of doubt.
If you contest it, get some form of legal representation, even legal aid. explain your case at contest mention to prosecutors and very good chances for you to have matter withdrawn.
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
