Hi, my name is Astushi, I am from the kansai region of Osaka and living in Sydney, so much f**king power from car, was tuned for ultimate response and powah! and is called R34 GTR, was tuned by company called MINES. I Have taken it up to 320kmh on the WANGAN C1 loop, so much POWER u throw into the shit very hard, so much G force of f**kign power. Was a member of midnight club in Japan before someone with motorbike acident stoped all of it, make me very mad. Now am In Sydney, who else love JAPan cars, I have brang over my car as personal import, where am i find where tuner are, am want to give advice and work as tuner for JAPAN cars here. Most cars hav seen are not good engineered.
https://www.sau.com.au/forums/topic/360076-so-fking-power-r34-gtr-bakemono/
Hope you and your family are coping alright with the recent earthquakes. Sucks that mother nature decides to screw over such a nice country :(
The import community here in Perth is pretty strong, I'm sure it'd be the same in Sydney :P
Not sure about the NSW forums, but the WA section has a consolidated workshop thread. If you don't have any luck with that, try using the search function. cheers.gif
Don't give the troll cannon fodder.
Welcome to SAU, Astushi. In fact, welcome to Australia.
Photos and specs would be great. I love R34 GTR. :)
Be warned though. I think roads and its rules are very different between Japan and Australia. Track would be a great place for your car though. :thumbsup:
Edited by VNS 24
Guest
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
