Hi, my name is Astushi, I am from the kansai region of Osaka and living in Sydney, so much f**king power from car, was tuned for ultimate response and powah! and is called R34 GTR, was tuned by company called MINES. I Have taken it up to 320kmh on the WANGAN C1 loop, so much POWER u throw into the shit very hard, so much G force of f**kign power. Was a member of midnight club in Japan before someone with motorbike acident stoped all of it, make me very mad. Now am In Sydney, who else love JAPan cars, I have brang over my car as personal import, where am i find where tuner are, am want to give advice and work as tuner for JAPAN cars here. Most cars hav seen are not good engineered.
https://www.sau.com.au/forums/topic/360076-so-fking-power-r34-gtr-bakemono/
Hope you and your family are coping alright with the recent earthquakes. Sucks that mother nature decides to screw over such a nice country :(
The import community here in Perth is pretty strong, I'm sure it'd be the same in Sydney :P
Not sure about the NSW forums, but the WA section has a consolidated workshop thread. If you don't have any luck with that, try using the search function. cheers.gif
Don't give the troll cannon fodder.
Welcome to SAU, Astushi. In fact, welcome to Australia.
Photos and specs would be great. I love R34 GTR. :)
Be warned though. I think roads and its rules are very different between Japan and Australia. Track would be a great place for your car though. :thumbsup:
Edited by VNS 24
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
