Pre Meet Dinner - Sau Movie Night 6 - Fast And The Furious 5
JEPPE
 Share
  • Replies 60
Do you mean... you + 3? I don't need car numbers just people numbers for when I book :)
woops, missed this, yes, +1 definite for me, but the other 2, said yeh no worries but you know how come people cancel out of no where (their those types)
Yup, TGIF it is, was only considering PP if the parking was hard but we can just park over the road. Will book today and confirm ^_^
Me + 1
Birds
Ashneel
Jesss14
sanjay
(OO)SKYLINE(OO)
xAlmoN
AussieR31 (possible + 1)
GTTR34
Wanzi + 1
KamikazeNinja34 + 2
Mohsen + 1
vspecIInur
miguelegant + 1
20-21
OK, serious review this time.
PLEASE NOTE: Reservation time has been changed so that TGIF can fit our numbers in. Booking is now for 5.30 with orders taken by 6pm. If you can't make it by this time - no stress - just check out the menu and either pm me or let me know on here what you want and I'll order it for you. It's set up to be finished by 7.30 as they have another booking and obviously we need to go by then but I think the earlier start will be good so we can mingle at the Pines before we head.
Location: TGI Fridays, Shop 250, Westfield Shoppingtown Cnr Williamsons & Doncaster Rds Doncaster VIC 3108
Parking: Across the road at the Hotel/BWS
Meet Time: 5.25pm Friday, 22nd April 2011
Leaving time: 7.15-7.30 to get to the Pines in time for departure
My mobile number is Oh-Four 38 898 780
I have booked for 26 but will reconfirm with TGIF on Friday. Please let me know of any updates.
Me + 1
Birds
Ashneel
Jesss14
sanjay + 1
(OO)SKYLINE(OO)
xAlmoN
GTTR34
Wanzi + 1
KamikazeNinja34 + 2
Mohsen + 1 (possible + 2)
vspecIInur + 1
miguelegant + 1
22 Confirmed, possible 25
BRO DNT MEET UP AT SHOPO OR PANCAKES... MEET UP AT APPLE PEAL CAR WASH.
This looks to be a big one.
I will update with more info shortly, but if everyone could please post up numbers that would be great.
Movie
Fast and the Furious 5
Meet location: Apple Peel Car Wash - 1 Fitzsimons Lane, Templestowe
Meet Time: 6:30-7:00pm on Friday, 22nd April 2011
Leaving time: 8pm (gets us good spots at the drive ins)
Movie time: ??? (sometime after 9pm)
Destination: Coburg Drive Ins
Price: $10 or less per person depending on numbers
Movie
you spoke to me earlier?
..........anybody organising any events or meetings near western suburbs ??????? no body.........................thats not fair :down:
log onto vic imports, a bunch from the west are heading down together
 Share
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
