k ive done all the searching bout this topic n ebc for the last 2 hrs and found useful info n stuff but not the answers i want
so heres my situation i have pfc with h/c with boost control kit. i give this boost kit a 6/10 cause it spikes a little at the top and my main problem is the way it boosts
it spools up just under 3k and hits max boost bout 6-6500rpm - way too late!
i'm after a ebc that will hit max boost close to 3000rpm as possible and spike as little as possible. i run 12-15psi on my 33 gtst.
any recommendations, opinions experiences would help heaps.thanks
https://www.sau.com.au/forums/topic/36016-i-want-max-boost/
Well i got a GReddy Profec B II, and it holds boost very very well and gets max boost around 2800 - 3200rpm. Check the for sale section ive got one for sale.
https://www.sau.com.au/forums/topic/36016-i-want-max-boost/#findComment-718437
Which turbo do you have and have you spent any time setting up and fine tuning you'r boost controller. To get the boost on as early as possible you need to ensure that the wastegate is held shut until around your max boost value
https://www.sau.com.au/forums/topic/36016-i-want-max-boost/#findComment-718769
i'm using stock r33 turbo and there are no adjustments on the pfc boost control to bring boost on earlier i had a dyno run and its running really rich like 11.6 right down to 10.2 and the pfc hasnt been tuned so i'll get that tuned and see how it goes after that . thanks evry1
https://www.sau.com.au/forums/topic/36016-i-want-max-boost/#findComment-719129
Guest INASNT
u have disconnected the stock boost solenoid havent u?
https://www.sau.com.au/forums/topic/36016-i-want-max-boost/#findComment-719366
