Mark saw your at today at MM and all I can say is fkn amazing, took my r35 to get it a RWC (moved to qld) and Trent showed me around the place. I'm gonna start looking into getting a set of track wheels and I'm thinking about the ones you have.
Gratz on the car, great work and a great team down at MM, I take my hat off to the lot of you :)
Will definitely try to get to a few events and make my way to WTAC in Syd
Edited by I8AV8
  • Replies 743
thanks! would be great to catch up at the track.:thumbsup:
Not yet.
Hehehe. Everyone's sweating on the freakin' carbon turning up.
Drew's is alive now and sounds grumpy. If all going well (when the carbon turns up) we will see you out at QR next week.
It's getting exciting isn't it.
Cheers
Marty
The hassle with the availability of the carbon parts is beyond a joke and we are far from impressed. Not only has it delayed test days in the past but also means that people involved now will have to work ALL weekend to even get the car to the track for monday testing. Not to mention the additional cost in freight/overtime etc. Not happy Jan!
Edited by MercuryMotorsport
At least you guys have a plan B for parts and can drive it. Drew has no front end at all and it's even due before your parts. Hope he pulls his finger out and finishes the carbon asap. We are starting to get a little nervous!
Cheers
Marty
Unfortunately it always seems to be outside contractors and suppliers who are the hold up whenever the pressure is on.
I hope you guys get it sorted, I'm super keen to see how it performs!
+1
When I worked as a small business manager I was project manager for many jobs, some going into the millions of dollars in costs.
Here in Adelaide we found the eastern seaboard states were never on the same 'level' with us timeframe-wise. If the interstate supplier had quoted 8 weeks for manufacture (add in 1 week for delivery, which I always arranged same time order was placed for product) we sort of had to allow say 10 weeks for manufacture, sometimes 12 (50% longer than quoted), simply because the late supply happened ALL the time. It was a guarantee that somewhere along the supply chain in NSW or Victoria a company would end up holding up our project. Main customer was the SA Govt. so it became nothing short of embarrassing. Didnt matter if I was in contact weekly to be updated on delivery timeframe, guaranteed the last week we'd get the 'sorry' speach......
Experienced this over 12 years in my job, it's the one part of the job I dont miss (got sacked once my kneecaps were surgically removed).
I hope you can work it out in good time.
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
