Mark saw your at today at MM and all I can say is fkn amazing, took my r35 to get it a RWC (moved to qld) and Trent showed me around the place. I'm gonna start looking into getting a set of track wheels and I'm thinking about the ones you have.
Gratz on the car, great work and a great team down at MM, I take my hat off to the lot of you :)
Will definitely try to get to a few events and make my way to WTAC in Syd
Edited by I8AV8
  • Replies 743
thanks! would be great to catch up at the track.:thumbsup:
Not yet.
Hehehe. Everyone's sweating on the freakin' carbon turning up.
Drew's is alive now and sounds grumpy. If all going well (when the carbon turns up) we will see you out at QR next week.
It's getting exciting isn't it.
Cheers
Marty
The hassle with the availability of the carbon parts is beyond a joke and we are far from impressed. Not only has it delayed test days in the past but also means that people involved now will have to work ALL weekend to even get the car to the track for monday testing. Not to mention the additional cost in freight/overtime etc. Not happy Jan!
Edited by MercuryMotorsport
At least you guys have a plan B for parts and can drive it. Drew has no front end at all and it's even due before your parts. Hope he pulls his finger out and finishes the carbon asap. We are starting to get a little nervous!
Cheers
Marty
Unfortunately it always seems to be outside contractors and suppliers who are the hold up whenever the pressure is on.
I hope you guys get it sorted, I'm super keen to see how it performs!
+1
When I worked as a small business manager I was project manager for many jobs, some going into the millions of dollars in costs.
Here in Adelaide we found the eastern seaboard states were never on the same 'level' with us timeframe-wise. If the interstate supplier had quoted 8 weeks for manufacture (add in 1 week for delivery, which I always arranged same time order was placed for product) we sort of had to allow say 10 weeks for manufacture, sometimes 12 (50% longer than quoted), simply because the late supply happened ALL the time. It was a guarantee that somewhere along the supply chain in NSW or Victoria a company would end up holding up our project. Main customer was the SA Govt. so it became nothing short of embarrassing. Didnt matter if I was in contact weekly to be updated on delivery timeframe, guaranteed the last week we'd get the 'sorry' speach......
Experienced this over 12 years in my job, it's the one part of the job I dont miss (got sacked once my kneecaps were surgically removed).
I hope you can work it out in good time.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
