I find it hard to believe that you've been able to do so much, basically like rebuild an entire car, in what seems to be a very short time frame.
Car projects seem to take forever, so this must have been very well researched and managed.
Fantastic effort all round, and thanks Mark for sharing.
Good luck next week, and I'm looking forward to seeing it in the flesh.
My son will be out there in an STi in the clubsprint class, but you're in another league.
Should be a great event, and hopefully a big crowd.
Brian
Hello Brian. When is Jim back and are you going to start some mods on yours yet?
Cheers
Marty
  • Replies 743
Anyone else notice that it hits 242km/h on the straight!
Yeah I took note of the 220km/h across the line (a good reference point for me).
Regarding the understeer issues - looks to me like it could run a fair chunk more front track under those big guards. But you've prob thought of that. I imagine there is no track width restrictions on WTAC ?
Edited by simpletool
Brian
We have only spent 4 months on the car, used over 1200 man hours and many many late nights and weekends to get the car to where it is now. I think the whole Mercury Motorsport team is looking forward to WTAC, so we can have a break from working on Mark's R35! :P
It has been a massive effort and I am extremely proud of the team, including our external contractors, who have pulled of what I think is an amazing build in such a short period of time.
100k on labour......ouch.
Just thought of something with such wild bodywork, how will you be bringing it down here? Getting it on most normal car trailers would surely be out of the question unless the front and rear bars/aero is designed to come off for transport?
SPECIAL THANKS TO DBA (Disc Brakes Australia) FOR SUPPLYING THEIR VERY LATEST R35 GTR ROTORS JUST IN TIME FOR WTAC!! Check these puppies out!!
A Few Other shots of the car....
Edited by MercuryMotorsport
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
