  • Replies 743
Suspension components in. getting ready for some more Aero development. limited resources available to develop the front last year. we hope we get more much needed front downforce this year. we had the rear detuned as much as possible due to issues at the front.
the graphic has the strut tower removed for simplicity.
it will go back in as you see in the picture on the previous page. the mount will be a the stock location but will be reinforced and with adjustability for roll cetnre tuning.
next year we may if time adn budget permits go for a compltetre geometry redesign. this year we are more aiming to better tune the suspension.
car is now over with Luke at '4Race' for him to work his magic with composites. aero is still being fine tuned as we speak.
massive amounts of work still to come. we will be cutting it fine again I am afraid but hopefully a few good suspension tuning sessions before we go down this time
  • 2 months later...
  • 1 month later...
still going, but to keep to budget things have been slow.
we won't be at WTAC this year but should have the car up and running for october at the latest and will have the bet part of the year leading up to WTAC 2013 for testing and will be ready to take on the cyber GTR.
the firewall was finished off and the rear guards done.
The final welds are being finished this week and the car will be off to paint very soon.
The extensive carbon body work is underway but it is all custom and slow going to get right.
will certainly have more pictures and information soon!
also working on a new transmission. fingers crossed it all works out. will be big news for R35 fans to have an aftermarket track/drag transmission which is lighter/stronger and retains AWD!
  • 5 weeks later...
firewall and chassis mods finished and primed ready for paint, those who know the front of an R35 will see what we have done...
Wow! That looks great Mark! Looks very professional and well thought. Much in the traditions of V8 supercars (in terms of suspension points triangulation)
Thanks
Ted
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
