  • Replies 743
thanks guys.
more pics courtesy of Paul Elliot of Elliot Creative Design Co
www.elliotcreative.com
Got to say, that tail wing looks massive!!!!
Also, from the design, it looks like ur using 2 pipe exhaust instead of the normal 4 ones. Any reason y?
Love the images of both race R35 builds in QLD seemingly taking place in sheds, how Australian :)
Maybe the Gov't can use it as an example of what can be built in a shed :P (http://www.mensshed.org)
Hi Eric,
yes the wing is massive but it is CFD tested by Scott Beeton. The plates (we will have spares) will be trimmed and tuned at the track test days. the front canards really arent a true representation of what they will look like as they are quite intricate and indeed also quite large.
the front carbon bumper is down in sydney with the carbon fabricators getting the pieces made and a fair amount of work will be involved in getting the front wings to secure to the car given the levels of downforce applied to them and the larger front splitter.
the exhaust will acually only be a single exit. it is for weight savings and reduced resistance/increased flow
lol, some of mankind's best work has taken place in sheds. though Luke's fabrication shed (one of the three sheds in the mercury complex) now has a lot of very cool toys at his disposal for these kind of jobs
Hi Eric,
Tight fit with the AMS alpha 10 kit
Engine back in
Gearbox and rear end dummy fitted so we can fabricate the custom fuel tank
Rear of car looks very mean!!
AP J hook rotors front and rear
AMS heat sheilds look right at home
ATI damper will help us nudge up the rev limit safely.
Very tight clearances for intercooler piping. We actually had to modify the alpha 10 turbo kit to accomodate the RHD car.
Edited by MercuryMotorsport
ah looks good. Is the carbon fibre dash lighter then the factory one? I haven't been on the inside of a 35 so i have no idea what all the dash is made of. Does look pretty damn cool though.
Considering the extent of the build, the time and expense making a custom carbon dash would be one hell of a waste if it wasn't lighter!
    • Hi all, I’ve just finished fitting the timing belt on my RB25, following the standard procedure: rotate the crank twice, release the tensioner, then tighten it down. The belt feels tight, and you can see that clearly in the picture below I’ve heard some people say it’s actually better for the belt to be slightly loose rather than too tight, as excessive tension can lead to snapping. So that’s in the back of my mind. What I’m seeing is this:  • At idle, the belt looks fine.  • But when cranking and especially when revving (around 3–4,000 RPM), there’s a momentary flap/flex or flicker in the belt, which I’ve tried to capture in the video. So my question is — based on what you see, is this slight belt movement something you’d consider normal, or am I just being OCD? Could this amount of movement cause sync issues? Or is it just a harmless bit of flex under load?   from what I know belt flap and flex is expected when crank spins up and pull cam with it Would appreciate any thoughts or similar experiences.     IMG_7656.mov IMG_7657.mov
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
