  • Replies 743
A car built for track racing, its always better to have the power band slightly more linear, not just nothing and then all hell breaks loose. I find that dyno run very nice and i can foresee some great corner exits with the power being delivered nice and smooth rather than ferocious to the point where you have to fight the car with oversteer.
Gordo dissecting the wiring harness
Dont let appearances deceive you, his fingers are nimble and quick. I reckon he could have done microsurgery but he chose the more noble art of modifying high performance Japanese cars.
and then below, the throw away bits. more weight savings!
Intense Handbrake, intense!
Are you sure you guys haven't actually been building this over the past two years secretly and land this bomb of a build on us now mate? :P
I'm so looking forward to seeing the big girl in action :)
long nights and weekends working on the car by all the lads at Mercury. super effort.
still plenty to do!
aim to have the car ready in close to final 'pre WTAC' spec for 26th July.
We have a few test dates prior to that planned at QR and Morgan park where the car will look a bit like frankenstein.
still plenty to do!
Well, it looks like the effort put in is being reflected in the build. Superb stuff!
And yes, Frankenstein.... been there with Mark a few times! :P
still plenty to do!
make sure you post the details as if im not doing anything would love to venture out for a looksies
Thanks for the walk around tour today Mark & the guys @ Mercury, much appreciated especially on a Sunday.
Some serious work going on there, and quite interesting to see how a few things have been approached. Weight stuff was really surprising indeed. Look forward to footage of 4WD power slide burnouts
:thumbsup:
how did the shake down go Mark?
any in car footage to be had as yet, or is it under cover for :ninja: reasons...
Didn't happen - tomorrow it'll be out Mark said today :D
:thumbsup:
Great to meet you guys.
Test day tomorrow, hoping things run smoothly!
Mark
Good luck with the test drive!
I am really looking forward to seeing your car at the track on the Nissan & AWD track day. Try not to lap me too often, please!
I absolutely love every aspect of the build. One of my son's who is working towards a mechanical engineering degree is fascinated by this thread.
Just one question. With the insane level of GO, should you maybe fit a similar level of WHOA?
If there was ever an argument for the benefits and safety that Carbon Ceramic discs can offer, your car is it BIG TIME!
Are there 'Carbon Ceramic' front rotors for the GTR and if so, should you fit them?
Have a great day tomorrow and see you on the 26th.
Kymbo
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
