Mark saw your at today at MM and all I can say is fkn amazing, took my r35 to get it a RWC (moved to qld) and Trent showed me around the place. I'm gonna start looking into getting a set of track wheels and I'm thinking about the ones you have.
Gratz on the car, great work and a great team down at MM, I take my hat off to the lot of you :)
Will definitely try to get to a few events and make my way to WTAC in Syd
Edited by I8AV8
  • Replies 743
thanks! would be great to catch up at the track.:thumbsup:
Not yet.
Hehehe. Everyone's sweating on the freakin' carbon turning up.
Drew's is alive now and sounds grumpy. If all going well (when the carbon turns up) we will see you out at QR next week.
It's getting exciting isn't it.
Cheers
Marty
The hassle with the availability of the carbon parts is beyond a joke and we are far from impressed. Not only has it delayed test days in the past but also means that people involved now will have to work ALL weekend to even get the car to the track for monday testing. Not to mention the additional cost in freight/overtime etc. Not happy Jan!
Edited by MercuryMotorsport
At least you guys have a plan B for parts and can drive it. Drew has no front end at all and it's even due before your parts. Hope he pulls his finger out and finishes the carbon asap. We are starting to get a little nervous!
Cheers
Marty
Unfortunately it always seems to be outside contractors and suppliers who are the hold up whenever the pressure is on.
I hope you guys get it sorted, I'm super keen to see how it performs!
+1
When I worked as a small business manager I was project manager for many jobs, some going into the millions of dollars in costs.
Here in Adelaide we found the eastern seaboard states were never on the same 'level' with us timeframe-wise. If the interstate supplier had quoted 8 weeks for manufacture (add in 1 week for delivery, which I always arranged same time order was placed for product) we sort of had to allow say 10 weeks for manufacture, sometimes 12 (50% longer than quoted), simply because the late supply happened ALL the time. It was a guarantee that somewhere along the supply chain in NSW or Victoria a company would end up holding up our project. Main customer was the SA Govt. so it became nothing short of embarrassing. Didnt matter if I was in contact weekly to be updated on delivery timeframe, guaranteed the last week we'd get the 'sorry' speach......
Experienced this over 12 years in my job, it's the one part of the job I dont miss (got sacked once my kneecaps were surgically removed).
I hope you can work it out in good time.
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
