  • Replies 743
Can you run the larger rear endplates without the 2nd wing element Mark, or do they serve little purpose when only running the single element?
Were you getting that much rear downforce that you were inducing understeer, have you considered running DRS with your Aeromotive wing controls :P
Sooooo much to do to finish off the car. Made a LONG list today of odds and ends so it looks like another big week at the workshop before we leave on wednesday morning.
Thanks to all the people who came out to the track over the last few days to check the car out and say hi.
Looking forward to seeing the car painted, stickered, and ready to kick ass at WTAC!!
I find it hard to believe that you've been able to do so much, basically like rebuild an entire car, in what seems to be a very short time frame.
Car projects seem to take forever, so this must have been very well researched and managed.
Fantastic effort all round, and thanks Mark for sharing.
Good luck next week, and I'm looking forward to seeing it in the flesh.
My son will be out there in an STi in the clubsprint class, but you're in another league.
Should be a great event, and hopefully a big crowd.
Brian
Edited by bcl
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
