I find it hard to believe that you've been able to do so much, basically like rebuild an entire car, in what seems to be a very short time frame.
Car projects seem to take forever, so this must have been very well researched and managed.
Fantastic effort all round, and thanks Mark for sharing.
Good luck next week, and I'm looking forward to seeing it in the flesh.
My son will be out there in an STi in the clubsprint class, but you're in another league.
Should be a great event, and hopefully a big crowd.
Brian
Hello Brian. When is Jim back and are you going to start some mods on yours yet?
Cheers
Marty
  • Replies 743
Anyone else notice that it hits 242km/h on the straight!
Yeah I took note of the 220km/h across the line (a good reference point for me).
Regarding the understeer issues - looks to me like it could run a fair chunk more front track under those big guards. But you've prob thought of that. I imagine there is no track width restrictions on WTAC ?
Edited by simpletool
Brian
We have only spent 4 months on the car, used over 1200 man hours and many many late nights and weekends to get the car to where it is now. I think the whole Mercury Motorsport team is looking forward to WTAC, so we can have a break from working on Mark's R35! :P
It has been a massive effort and I am extremely proud of the team, including our external contractors, who have pulled of what I think is an amazing build in such a short period of time.
100k on labour......ouch.
Just thought of something with such wild bodywork, how will you be bringing it down here? Getting it on most normal car trailers would surely be out of the question unless the front and rear bars/aero is designed to come off for transport?
SPECIAL THANKS TO DBA (Disc Brakes Australia) FOR SUPPLYING THEIR VERY LATEST R35 GTR ROTORS JUST IN TIME FOR WTAC!! Check these puppies out!!
A Few Other shots of the car....
Edited by MercuryMotorsport
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
