  • Replies 743
is it heavier in the back than the front? is that why you reversed it on the trailer?
It is actually the only way the car will fit!! It is too wide at the front to get onto the trailer. With all of the tools/gear loaded onto the trailer and with the rear mounted gearbox, the trailer is very well balanced in this configuration.
Its very hard to have expectations, but we would like to be sub 1:33's but we have zero experience at EC with this car. I guess that is half the fun! :)
1:33 is seriously quick & in fact quicker than aust superbike class :)
do u plan to take it to wakefield as well?
Being Brisbane based, it is hard to travel interstate to track days, especially as Mark (the owner of the car), is VERY busy professionally and has 3 kids to boot. I think we were lucky to get him out of Brisbane for WTAC!
yeah it's impossible to predict times for a first event of a car. I'm sure they'll just be happy if it runs cleanly and comes back with some good data on where to go from here. it could do a flat 30 or it could be a flat 40.... only one way to find that out. :)
I would pay good money for it to do a flat 30! Might be necking myself if it does a flat 40!!! :P
Below is the results from last year so will be interesting to say the least. There were some big names in the 1:35 plus area so only time will tell.
1 Tarzan Yamada- CyberEVO- Mitsubishi EVO- 1:30.5870*
2 David Empringham- Sierra Sierra- Mitsubishi EVO- 1:31.8840 +0:01.2970
3 Tarzan Yamada- Tomei/Cusco- Subaru Impreza WRX- 1:31.9010 +0:01.3140
4 Warren Luff- Prep'd Motorsport- Lotus Elise- 1:32.2730 +0:01.6860
5 K Sasaki- Pan Speed Racing- Mazda RX-7- 1:32.4540 +0:01.8670
6 Kinoshita Mitsuhiro- Pro Staff R-Magic- Mazda RX-7- 1:33.5050 +0:02.9180
7 Mark Berry- Advan/Hi Octane Racing- Nissan Skyline R34 G- 1:34.1090 +0:03.5220
8 David Loftus- BSM Motorsport- Nissan Skyline R32 G- 1:35.8760 +0:05.2890
9 Garth Walden- Tilton Interiors- Mitsubishi EVO- 1:37.0590 +0:06.4720
10 Peter Lucas- Kirrapak Racing- Lotus Elise HPE- 1:37.4240 +0:06.8370
11 Russell Newman- Advan/Hi Octane Racing- Nissan Skyline R32 G- 1:38.2190 +0:07.6320
12 Mal Rose- Mal Rose Racing- Holden Commodore- 1:39.3230 +0:08.7360
13 Jose Fernandez- Fernandez Motorsport- Ford Falcon- 1:40.2170 +0:09.6300
14 Cameron Dyal- APC Racing- Mitsubishi EVO- 1:42.7990 +0:12.2120
15 David Hommer- 999 Automotive- Honda Integra Type R- 1:46.0140 +0:15.4270
Cheers
Marty
i have been told when loading a car onto a trailer not to put it backwards.
due to 80% of the weight being behind the axle.
other than that epic, and i cant wait to make the trip over there tomorrow!!
R35 is a bit different to most cars. particularly a track R35. don't forget they have a transaxle so lots of weight in the rear and consequently less weight up front. and don't forget they balanced it further with tools etc. but the point is if the car only fits backwards, you put it on backwards.. I don't think driving it to sydney was an option...
Cheers
Marty
agreed. I reckon if they break a 35 for their first big event that will be a massive achievement. anything past that is gravy. hell under a 40 is a big effort.
Given both cars (R35's) are basically just built and untested if they can beat the High Octane R32 they will be doing very very well IMO.
Both these cars are amazing bits of gear - but I think they will still need a few more miles under their belts - and a bit more tweaking - before their true potential can be realized. I don't think bolting them together and just doing 1-2 days testing will quite get them there yet.
But anything under a 1.40 will be a really great effort.
No doubt this year will be a massive learning year for them both - and look out seriously for them in 2012.
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
