It's very easy to put together braided lines, the only issue as mentioned earlier is any stray wire messes up the thread in the fittings = chop the line and bin the fitting. You'll only do it once.
Twin feed or single, either way I would be tuning with individual EGT. The cost is negligible and they're easily removed once the car is tuned. I have very large corrections, eg the largest trim is -4'ish% to +13% on one cylinder (not 6), depending on manifold pressure.
How accurate are the sensors? There would be a discrepancy between them too right? What unit do you use to read/log the temps and what do you plug the hole with when you are finished? I guess there is variation with injector flow if the tune is out that much between cylinders...
I have a V6 so twin rails. I just finished making a twin Walbro intank setup with -6 lines to each rail, I didn't want issues with one pump failing and not knowing so this way, and with 2 one way valves before the reg, I can separate the flow to each rail completely. That way 3 injectors will fail completely if one pump goes. I will only have one return from the reg though. All teflon lines as i'm running Eflex.
The idea is to eliminate pressure drop yes, but the actual problem is transience between individual cylinder fuel pressure etc.
twin entry rail goes some way to making this problem better.
obviously you dont have a hugely diminishing fuel pressure over the length of the rail, as the FPR controls the global rail pressure (to a degree).
The thermocouples are accurate to within a couple of degrees - far more accurate than required. Plugging the hole is easy using a bung. There are plenty of cheap logging options but I was using Innovate gear.
The injectors tested within a couple percent before installing, and a second motor with a completely different set-up (not my car) had near on identical results with different logging gear.
I would encourage any modifier to find out for themselves, cheap insurance and far better than relying on (untested) forum theory to tell you where to stick your highest flowing injector.
  • 5 months later...
it's a piece of cake mate. remove the current fuel line between fuel filter and rail. now put on a new shorter line which feeds a Y piece (into the bottom of the Y). to the top of the Y you add 2 new fuel lines, run one to the back of the rail and one to the front. if you are really pedantic try and keep them the same length. then mount the reg on the drivers side strut tower, run a new reg feed from the middle port on the fuel rail, then return from the bottom of the reg into the fuel return line back to tank. easy. can use dash fittings and braided hose if you like, or otherwise just normal hose barbs and 8mm fuel hose with fuel hose clamps is fine too.
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
