It's very easy to put together braided lines, the only issue as mentioned earlier is any stray wire messes up the thread in the fittings = chop the line and bin the fitting. You'll only do it once.
Twin feed or single, either way I would be tuning with individual EGT. The cost is negligible and they're easily removed once the car is tuned. I have very large corrections, eg the largest trim is -4'ish% to +13% on one cylinder (not 6), depending on manifold pressure.
How accurate are the sensors? There would be a discrepancy between them too right? What unit do you use to read/log the temps and what do you plug the hole with when you are finished? I guess there is variation with injector flow if the tune is out that much between cylinders...
I have a V6 so twin rails. I just finished making a twin Walbro intank setup with -6 lines to each rail, I didn't want issues with one pump failing and not knowing so this way, and with 2 one way valves before the reg, I can separate the flow to each rail completely. That way 3 injectors will fail completely if one pump goes. I will only have one return from the reg though. All teflon lines as i'm running Eflex.
The idea is to eliminate pressure drop yes, but the actual problem is transience between individual cylinder fuel pressure etc.
twin entry rail goes some way to making this problem better.
obviously you dont have a hugely diminishing fuel pressure over the length of the rail, as the FPR controls the global rail pressure (to a degree).
The thermocouples are accurate to within a couple of degrees - far more accurate than required. Plugging the hole is easy using a bung. There are plenty of cheap logging options but I was using Innovate gear.
The injectors tested within a couple percent before installing, and a second motor with a completely different set-up (not my car) had near on identical results with different logging gear.
I would encourage any modifier to find out for themselves, cheap insurance and far better than relying on (untested) forum theory to tell you where to stick your highest flowing injector.
  • 5 months later...
it's a piece of cake mate. remove the current fuel line between fuel filter and rail. now put on a new shorter line which feeds a Y piece (into the bottom of the Y). to the top of the Y you add 2 new fuel lines, run one to the back of the rail and one to the front. if you are really pedantic try and keep them the same length. then mount the reg on the drivers side strut tower, run a new reg feed from the middle port on the fuel rail, then return from the bottom of the reg into the fuel return line back to tank. easy. can use dash fittings and braided hose if you like, or otherwise just normal hose barbs and 8mm fuel hose with fuel hose clamps is fine too.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
