Fs: 240K '77 Sedan
Hey guys,
I recently picked up a 5 spd manual 240K Sedan with the intention of having as my weekender car and fixing up here and there.
Unfortunately my V35 Sedan's radio died and now it needs replacing, (Approx. $1300).
So with financial constraints I'm forced to put the dream on hold for a little while and put the 240K up for sale.
The car set me back $2000 and if it means going to someone that'll look after it and restore it I'd be happy selling it for what it cost me.
Good clean, mechanically sound car.
Registered
Low kms (153k genuine kms)
Log book, original purchase reciept, nissan workshop manual
Interior has been covered from birth with wool seat covers (Can be supplied if you really want:)
Dash and doors been regularly coated with protectant
Here's some pics... More to follow.
Car is in Adelaide.
041 393 1027 - Marcus.
PM this guy , Chris Rogers He does lots of custom work on V series Skylines thinks like aftermarket cruise control that uses the factory buttons and that kind of thing, he can probably sort yours out.
cheers
Jason
Yeah, he's got the stereo at the moment.
That is who quoted $1300 :) CD Changer stripped a gear .. or ten.
So it's either replacement unit or iPod in.
I'd rather the full replacement for resale value.
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
