hi guys,
these parts are from my previous black R32 GTR, aka GO21LA! as pictured below...it was a very clean car, my mate bought the engine so i decided to wreck the rolling chassis as parts.
i will be adding to this thread a lot more parts over the following weeks, i just need to pace myself with the parts i sell so i can keep track of things :)
if you need anything else in particular, chances are that i’ll have it so just ask me (except for the chassis, front panels & rear subframe)
1. gearbox $900.00
2. front door trims $240.00
3. rear door trims $200.00
4. dash pad (no cracks or bubbles – perfect condition) $150.00
5. dash cluster with 180km/h speedo (showing 65000km) $200.00
6. doors (includes tinted glass & power window mechanisms) $350.00
7. front windscreen (with antenna) $200.00
8. rear tail lights $200.00
9. new ASI radiator (unopened in box) $170.00
10. mirrors $120.00 sold
11. front lip $200.00 sold
12. factory afm $70.00
It’s a Bing Lee sale where “everything is negotiable” :)
regards,
marko
0405 336 843
Edited by Marko R1
  • Replies 386
Hi do you have the factory airbox?
Secondly, what are the specs of the radiator?
Sorry I don't have the airbox, I'm actually looking for the factory airbox, exhaust and a top valley cover myself.
The radiator is 52mm still in box to suit r32gtr. I had the exact same radiator in the black gtr and the the temperature dropped significantly less than the standard radiator. That was with a 700bhp engine!
Center and passenger side dash vents condition and price please
Centre dash vent I sold a few weeks ago, sorry.
Passenger side vent is unmarked and not cracked like most of them. I bought 1 yrs ago for $90...you can have it for $75 :) (this includes postage if you're not in syd)
Hey mate how much for the rear trim the part surrounding the back side windows and where are you located?
Cheers
These are already sold, sorry mate
Hey interested in the dash are you able to tell me how much posted to 4107 brisbane
also seen you were chasing a factory airbox i've got one on here for sale at the moment if your
interested come with all plastic pipes attached to the intake of the airbox
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
