  • Replies 386
hi mate you wouldnt have a wiring loom hanging around would you?
I have the engine wiring loom but its cut from the car, do u need the complete loom or more so the actual plugs?
quick update of remaining parts with adjusted pricing on clutch & wheels + some new parts...
1. front door trims - $140
2. rear door trims - $100
4. front windscreen - $90
5. rear tail lights - $100
6. factory afm - $50
7. blitz icolor dual solenoid dsbc boost controller (with user manual) - $500
8. attesa 4wd pump - $180
9. hicas pump - $70
10.dash vent (passenger side) - $40
11.left cv with knuckle assembly - $80
12.right cv with knuckle assembly - $80
13.drivers side window/mirror control - $50
14.sun visors - $10
15.complete boot trim - $80
16.instrument panel surround (does not have headlight switch) - $20
17.power steering line - $10
18.caster (radius) rods - $40
19.radiator overflow bottle - $10
20.passenger & drivers side door sill garnish - $40
21.door seal finish - $10
22.factory side skirts (black) - $140
23.front subframe - $20
24.bootlid rubber seal (no tears) - $10
25.power steering reservoir - $10
26.passenger side window switch - $20
27.os giken triple plate clutch - $1400 PRICE DROP $1350
28.full set of nissan wipers - $50
29.2 x rb26 timing belts (have done less than 5000km) - $30 EACH
30.2 x rb26/30 timing belts (have done less than 2000km) - $30 EACH
31.front sway bar with linkages & brackets - $40
32.cometic metal head gasket (has done 30min of work) - $80
33.interior a/c control unit - $80
34.17" forged Work BRS Poison wheels with bridgestone tyres - $800 PRICE DROP $750
35.rear boot plastic trims which sit on the top of the rear tailgate - $40
36.momo gearknob - $50
38.factory rb26 harmonic balancer - $80
39.gearbox cross member - $30
hi mate how much for the tail lights posted to melb ? 3805
postage works out to be only $11 to 3805.
total price including tail lights is $110 to your door :)
How much for the under car surge set up and also do u have the front seats for sale pm me the price
Thanks
Seats are long gone.
Under car surge tank is a $1400 system with receipts, I want $700 for it. Done less than 2000km.
Update of remaining parts...the door garnish’s are back for sale as well as the bosch 044 fuel pump with factory cradle!
2. front windscreen - $90
3. rear tail lights - $100
4. blitz icolor dual solenoid dsbc boost controller (with user manual) - $500
5. attesa 4wd pump - $180
6. hicas pump - $70
7. dash vent (passenger side) - $40
8. left cv with knuckle assembly - $80
9. right cv with knuckle assembly - $80
10. drivers side window/mirror control - $50
11. sun visors - $10
12. complete boot trim - $80
13. instrument panel surround (does not have headlight switch) - $20
14. power steering line - $10
15. caster (radius) rods - $40
16. radiator overflow bottle - $10
17. passenger & drivers side door sill garnish - $40
18. door seal finish - $10
19. factory side skirts (black) - $140
20. front subframe - $20
21. bootlid rubber seal (no tears) - $10
22. power steering reservoir - $10
23. passenger side window switch - $20
24. os giken triple plate clutch - $1350
25. full set of nissan wipers - $50
26. 2 x rb26 timing belts (have done less than 5000km) - $30 EACH
27. 2 x rb26/30 timing belts (have done less than 2000km) - $30 EACH
28. front sway bar with linkages & brackets - $40
29. cometic metal head gasket (has done 30min of work) - $80
30. interior a/c control unit - $80
31. 17" forged Work BRS Poison wheels with bridgestone tyres - $750
32. rear boot plastic trims which sit on the top of the rear tailgate - $40
33. momo gearknob - $50
34. factory rb26 harmonic balancer - $80
35. gearbox cross member - $30
36. bosch 044 fuel pump intank setup with factory cradle - $100
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
