  • Replies 386
Hey mate, got the coil pack harness? If so is it in good nick?
i do but unfortunately i cut it from where it meets the firewall - i only have the front half of the harness with all plugs
hows it goin? you still got the passenger side window switch and front subframe? if so how much to post to 2620? cheers. oh and do you still have the dash clock also?
passenger switch & dash clock are sold
subframe is still here :)...freight is $35 to your door (due to the size & weight of it)
another update, as below!
1. dtm rush wheels 18x9.5 +25 offset with kumho tyres 70% tread (1 damaged wheel & repairable by "Magman" for under $100) – price drop $650
2. 17" forged Work BRS Poison wheels 17x9 + 29 offset with bridgestone tyres – price drop $350
3. factory triple gauge in centre console – $70
4. 2 x earl's fuel filter with 5/16 barb push on fittings – price drop $15 each
5. front sway bar with linkages & brackets - $20
6. rockford fosgate 'punch series' 2 way speakers with additional tweeter & cross over (retail $500) – price drop $140
7. attesa 4wd pump – price drop $100
8. hicas pump – $30
9. power steering line - $5
10. radiator overflow bottle - $5
11. front subframe - $10
12. bootlid rubber seal (no tears) - $5
13. power steering reservoir (no cap) - $5
14. rb26 timing belt (has done less than 5000km) - $20
15. factory rb26 harmonic balancer – $50
16. gearbox cross member - $20
17. momo gear knob - $30
18. nismo black urethane gear knob – price drop $70
Marko, Just tried to ring you.. but you didn't answer.
Anyway, have you still got the BOV return pipe that runs behind the intercooler?
parts remaining as below:
1. 17" forged Work BRS Poison wheels 17x9 + 29 offset with bridgestone tyres – $350
2. factory triple gauge in centre console – $70
3. 2 x earl's fuel filter with 5/16 barb push on fittings – $15 each
4. front sway bar with linkages & brackets - $20
5. rockford fosgate 'punch series' 2 way speakers with additional tweeter & cross over (retail $500) – $140
6. attesa 4wd pump – $100
7. hicas pump – $30
8. power steering line - $5
9. radiator overflow bottle - $5
10. front subframe - $10
11. bootlid rubber seal (no tears) - $5
12. power steering reservoir (no cap) - $5
13. rb26 timing belt (has done less than 5000km) - $20
14. factory rb26 harmonic balancer – $50
15. gearbox cross member - $20
16. momo gear knob - $30
17. nismo black urethane gear knob – $70
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
