Hey Marko, I'll take the timber spare wheel cover thingy.
Also if youw ant to seperate the boot carpet only, don't need the side trims.
Do you also have the dust cover that sits under the engine?
PM me your details mate, dependign on location will organise to meet up soon.
Cheers
Bobby
  • Replies 386
Cheers
Bobby
i have sent you a pm with my details for the wheel cover & carpet boot
i dont have the cover that sits under the engine
$750 for the box !!!
its in perfect condition mate that's a F#$@ steal, some very happy man will by it .
yes it is nick & you've driven my black gtr, box is nice to drive as well!
19. front upper control arms with nolathane bushes (done 2000km) - $150 PRICE DROP $120/quote]
still got these? will you post to Perth? pm me
thanks,
Clayton
thanks,
Clayton
yes i do - if you want them, i'll cover postage :)
i'll pm you my bank details
Hi interested in your steering rack. Is it in good working condition?
Also how much shipped to melbourne 3133?
steering rack is good as new.
shipping seems to be about $20, as per auspost.com.au
if its anymore than that, i'll wear the cost :)
Hey mate any chance you still have the rotary light switch ?? If so how much with postage to 3805 VIC
EDIT: Just saw that you dont have the switch lol
I sold the light switch a while ago.
Its 1 of those high demand parts though, speaking of high demand - I think I received dozens of pm's on front end parts, in particular front bar and front reo.
I can see an opening for a business venture, source aftermarket front end bits for an r32gtr and u will be a rich man!
52. nissan rear bootlid badge SOLD
i still have the following genuine badges:
- GTR bootlid (black)
- bonnet badge
- front ¼ panel GT badges
1. gearbox - $750
2. front door trims - $200
3. rear door trims - $170
4. dash pad - $150.00 SOLD
5. dash cluster with 180km/h speedo (showing 73000km) - $150
6. doors (includes tinted glass & power window mechanisms) - $320
7. front windscreen (with antenna) - $150
8. rear tail lights - $160
9. new ASI radiator (unopened in box) - $150
10. mirrors - $120.00 SOLD
11. front lip - $200.00 SOLD
12. factory afm - $50
13. blitz icolor dual solenoid dsbc boost controller (with user manual) - $600
14. attesa 4wd pump - $350
15. input shaft for transfer case/4wd - $50
16. work wheel nuts - $120
17. hicas pump - $120
18. ohlins suspension, very nice ride & not too hard/bumpy like most coilovers - $400
19. front upper control arms with nolathane bushes (done 2000km) - $120 SOLD
20. speedo cable which has done 2000km - $70
21. dash clock - $40
22. rear subframe 'pineapples' to lock in blown out bushes & stiffen rear end - $70
23. spare wheel - $50
24. dash vent (passenger side) - $50
25. nismo engine oil cap - $20
26. left cv with knuckle assembly - $150
27. right cv with knuckle assembly - $150
28. torque split controller 'extreme tsc' - $100
29. drivers side window/mirror control - $80
30. sun visors - $30
31. complete boot trim - $160
32. timber wheel cover - $20 SOLD
33. centre console stereo fascia (late model grey wrinkle finish) - $50 SOLD
34. leather boots for gear lever & hand brake - $50 SOLD
35. instrument panel surround (does not have headlight switch & wiper button) - $40
36. power steering line - $40
37. caster (radius) rods (bushes are good) - $80
38. radiator overflow bottle - $30
39. passenger & drivers side door sill garnish - $80
40. door seal finish - $30
41. front window garnish - $30 pair SOLD
42. factory side skirts - $180
43. steering rack - $100 SOLD
44. front subframe - $60
45. front indicator - $90 SOLD
46. bootlid rubber seal (no tears) - $30
47. power steering reservoir - $20
48. earls braided brake lines (front and rear) - $120
49. factory blow off valves complete with plumbing - $130
50. gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - $350
51. 'race brakes' race compound pads front & rear - $180
52. passenger side window switch - $40
52. genuine black gtr bootlid badge - $70
53. genuine bonnet badge - $30
54. genuine front ¼ panel gt badges - $60
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
