  • Replies 386
after the fuel cap/boot cable? price delivered to melbourne vic?
cheers
Plastic fuel cap I have.
Are u referring to the boot release cable which runs from the drivers seat?
R32 GTR Centre Instrument Console Black Surround - the piece that surrounds the 3 x gauges, aircon, radio, gearshift.
Have, not have? Condition, photo, price?
Rgds ... Les
Rgds ... Les
Sorry sold that last week with the dash, hard to get as well
Hey Marko, do you have the drivers review mirror rubber seal? Mine makes a slight whistle which is annoying.
Not sure what u are referring to mate, can u get a pic?
This is what is left – still a lot to go (ive added 1 new item at the end of the list)!
I have more items to sell which I’ll add over the next few days...in the interim, please make offers as I will consider this!
1. gearbox - $750
2. front door trims - $200
3. rear door trims - $170
5. dash cluster with 180km/h speedo (showing 73000km) - $150
6. doors (includes tinted glass & power window mechanisms) - $320
7. front windscreen (with antenna) - $150
8. rear tail lights - $160
12. factory afm - $50
13. blitz icolor dual solenoid dsbc boost controller (with user manual) - $600
14. attesa 4wd pump - $350
15. input shaft for transfer case/4wd - $50
16. work wheel nuts - $120
17. hicas pump - $120
18. ohlins suspension, very nice ride & not too hard/bumpy like most coilovers - $400
20. speedo cable which has done 2000km - $70
21. dash clock - $40
22. rear subframe 'pineapples' to lock in blown out bushes & stiffen rear end - $70
23. spare wheel - $50
24. dash vent (passenger side) - $50
26. left cv with knuckle assembly - $150
27. right cv with knuckle assembly - $150
28. torque split controller 'extreme tsc' - $100
29. drivers side window/mirror control - $80
30. sun visors - $30
31. complete boot trim - $160
35. instrument panel surround (does not have headlight switch & wiper button) - $40
36. power steering line - $40
37. caster (radius) rods (bushes are good) - $80
38. radiator overflow bottle - $30
39. passenger & drivers side door sill garnish - $80
40. door seal finish - $30
42. factory side skirts (black) - $180
44. front subframe - $60
46. bootlid rubber seal (no tears) - $30
47. power steering reservoir - $20
48. earls braided brake lines (front and rear) - $120
49. factory blow off valves complete with plumbing - $130
50. gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - $350
51. 'race brakes' race compound pads front & rear - $180
52. passenger side window switch - $40
52. genuine black gtr bootlid badge - $70
53. genuine bonnet badge - $30
54. full set of front & rear gtr seat belts in good condition - $100
Hey mate just wondering if i can get some photos of the torque split controller. Does it have the ablity to switch between 4wd and 2 at all?
Cheers matt
Edited by 32vspec2gtr
Cheers matt
Hey mate just wondering if you have the speedo cable at all. Cheers matt
speedo cable has done 2000km (like new) - pic attached ($70)
torque split controller also only done 2000km - pic attached. u can run 2wd & 4wd. in 4wd mode u can adjust the power to the front wheels from 1 to 10. position 1 is standard & position 10 is 50/50 split from front to rear ($100)
Edited by Marko R1
Cheers matt
pm sent matt!
OS Giken triple plate clutch 'R3C' with billet clutch cover which has done 2000km. it includes everything you need to bolt straight into your car (i.e. flywheel, clutch disks, center plates, pressure plate, clutch cover bolts, clutch cover, release bearing & associated bolts).
In case you are wondering what 'R3C' stands for...
R - means its 'billet'
3 - means its a triple plate
C - means it hss the largest diameter plates @ 215mm
You can also refer to this link: http://www.osgiken.net/products/racingmultiplate.html
I originally bought this from otomoto for $3000 as per this link: http://www.otomoto.com.au/osgiken/r3c_tri_plate.htm
Selling for $1800 ono :)
For all interstate buyers - PLEASE NOTE:
I have very competitive door to door courier pricing & to give you an idea on this, to post the steering rack interstate (which is about 1.5m in length & about 10kg) comes to only $15 :)
I can pretty much cover all freight costs on most of these parts advertised in this thread as an incentive :)
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
