  • Replies 386
Have u got the whole blinker switch? My contactors dont work inside it causing 1 of my high beams not to work for rego. Would be great if u had that!
yes i have the blinker switch, the 1 that sits in the steering column right?
Edited by Marko R1
yeah in goes right into the steering column. Should be a white mechanism. What ever looks like the whole part ill buy. If its not to much trouble to take a picture?
ok - here is a pic of the actual mechanism for the indicator & another item which runs on the back of the steering wheel. the problem you are having will the rectified with these parts :)
aight cool ill pm you from now on :)
This is now sold!
this is another update of what is left with adjusted pricing...
1. front door trims - $160 PRICE DROP $140
2. rear door trims - $100
3. dash cluster with 180km/h speedo (showing 73000km) - $90 PRICE DROP $70
4. front windscreen - $90
5. rear tail lights - $100
6. factory afm - $50
7. blitz icolor dual solenoid dsbc boost controller (with user manual) - $500
8. attesa 4wd pump - $200 PRICE DROP $180
9. hicas pump - $70
10.dash vent (passenger side) - $40
11.left cv with knuckle assembly - $90 PRICE DROP $80
12.right cv with knuckle assembly - $90 PRICE DROP $80
13.drivers side window/mirror control - $50
14.sun visors - $10
15.complete boot trim - $80
16.instrument panel surround (does not have headlight switch) - $20
17.power steering line - $10
18.caster (radius) rods - $40
19.radiator overflow bottle - $10
20.passenger & drivers side door sill garnish - $40
21.door seal finish - $10
22.factory side skirts (black) - $150 PRICE DROP $140
23.front subframe - $30 PRICE DROP $20
24.bootlid rubber seal (no tears) - $10
25.power steering reservoir - $10
26.passenger side window switch - $20
27.os giken triple plate clutch - $1450 PRICE DROP $1400
28.full set of nissan wipers - $50
29.2 x rb26 timing belts (have done less than 5000km) - $50 each PRICE DROP $30 EACH
30.2 x rb26/30 timing belts (have done less than 2000km) - $50 each PRICE DROP $30 EACH
31.front sway bar with linkages & brackets - $50 PRICE DROP $40
32.cometic metal head gasket (has done 30min of work) - $100 PRICE DROP $80
33.interior a/c control unit - $90 PRICE DROP $80
34.17" forged Work BRS Poison wheels with bridgestone tyres - $850 PRICE DROP $800
35.rear boot plastic trims which sit on the top of the rear tailgate - $40
36.momo gearknob - $60 PRICE DROP $50
37.bosch 044 fuel pump intank setup with factory cradle - $120 PRICE DROP $100
38.factory rb26 harmonic balancer - $100 PRICE DROP $80
please search through the prior pages to see pics of the above listed parts :)
Edited by Marko R1
just confirm for me surge tank + pumps are gone?
sorry richard - sold a few days ago.
only have the single in-tank 044 for sale.
i also have an undercar surge tank with an 044 which is a much better setup than the boot setup i had but haven't removed it as yet...here is a pic :)
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
