ok so at low speeds, especially in stop / start traffic, whenever I give a slight bit of acceleration to get the car moving, I hear this 'squishing' noise from the rear of the car just as i let the clutch out..
Then whilst gently accelerating in traffic i.e gas on/off etc, if i stop accelerating before 20km/h or so it makes this slight metal tap noise (only once) but if i tap the gas again it will make the same 'clink' or noise.
I noticed it about 12 months ago, drained and replaced the diff oil - didnt quite go away but it made a difference noise wise.. the last month or so the noise has got a little bit worse. The car doesnt seem to be affected performance wise.
any ideas? I'd get a video / audio but the car is too loud
https://www.sau.com.au/forums/topic/360239-r33-diff-problem/
yeah that pretty normal smell wise. Maybe stick a bottle of Fiction Modifying additive to see if that fixes your problem. I use it in my 2-way to stop it clunking and grinding, i use penrite additive but chryler-jeep and ford motorsport also make it
it maybe a thought to check your bearings for your rear wheel hubs. i had same issue and one of the bearings was farkd.
replaced that and it was all fine.
also check your cv joints for play as that can do it too
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
