Hey All,
Well ive finally decide to sell my little Black R32 Gts-t, but 2 months ago i forgot that i was defected for my Pod, next comes a letter in the mail....
"Notice of registration Cancellation" !!! over a ****ing pod that leaks a little bit of gas ??....
Now, the plot thickens, prior to this defect i have thrown a HKS front mount intercooler in the bay, and in order to clear my defect i had to put the standard airbox on, and just as things couldnt get any worse .... It didnt fit because of the piping... now i know alot of you will say .. "just make up a custom box" but i gonna take guess here that .... It needs to be engineered ? and the plot thickens again, theres no engineers for 2 hours were i live ... Great.
One more question, can i take off the piping on the FMIC thats in the way temporarly, put the standard box on and take it to get cleared or will the car **** up ?
So i should do what exactly ?
Please tell me that at least 1 person has been through this or similar ....
Cheers all !
Mitch
https://www.sau.com.au/forums/topic/36028-im-sick-of-god-damn-defects/
I met a whole buncha bastards who wouldn't sign off on my defect unless it was back to the original airbox.
Liek yu0 kn0... get farked...
Not after a spent the money on a new pod and fiberglass box.
Unfortunately most places who can clear defects won't jeopardise their license for only $16.50...
T.
Well, i just had an idea to cut away a bit of the airbox so it bypasses the piping... so im going to do that 2morrow....
BTW. Are the RTA leanient with defects that lead to rego cancellations ? will that let me just reactivate the rego for a small fee ?
Cheers all and thanks for the replys
Just cover the pod with a box and go to your local blue slip garage and get them to check it. It took me longer to pop the bonnet lever and raise the bonnet than it took for them to inspect everything.
To be honest their is nothing illegal about a 'pod filter' but lets not get into that again...
:D
I had one and got defected. I went to a place near me, sat the box in dodgily and just swapped it over when I left again. he was cool about it because he checked it with the standard box, didn't he? if I put it on again after he leaves it isn't his problem
I now have a standard box with K & N panel filter. I also have a HKS FMIC, but the piping fits perfectly with the box, is yours a proper kit??
why you stressing for about the pod and rta, trust me you dont have to think about them, i get those leters all the time about defects and cancelation of rego, then licence if you dont fix it, but if your in sydney message me i have someone who will clear your defects and you dont even have to change anything.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
    • Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
    • Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
    • I sourced my silicone hose kits from Just Japanese. Their current link is what I posted above but supplier might have changed over the decades.
