Hey Guys,
Im looking at getting a Haltech P2000 Ecu with IQ3 Street dash.
i have found a package on ebay for $2965 US which is abit cheaper due to aus $$$.
i just want to make sure i get the right ecu/wiring lead kit i need,
My car is a silvia and i have a complete GTR R32 Engine wiring loom, but im unsure what year model this wiring loom is out of, do all the R32 GTRs have the same wiring loom/ecu or are they different.
here a link to what im looking at http://cgi.ebay.com/ebaymotors/HALTECH-P2000-ECU-kit-IQ3-DASH-Wideband-street-kit-_W0QQcmdZViewItemQQhashZitem1c154ba9a1QQitemZ120616364449QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
thanks guys
Also the car is going to be using E85.
i have asked the seller from ebay these questions and this was his reply to me was.
Daniel,
The P2000 can control your engine also, but it will either have to be wired up to the engine or use one of our patch loom kits , here are your options:
1.P2000 flying lead kit , this kit has to be wired up into your engine (price with dash $2965 ) item # 120616364449
2.P2000 R32 patch loom kit,this kit plugs into your current factory harness(price with dash $2965)item #120615981060,(advertised for 300zx however it is the same kit)
3.Pro Platinum R32 Plug and Play ECU , this ECU plugs straight into your factory harness also (price with dash $2717) item # 110591763827
Regarding the MAP sensor , I'll suggest the Haltech 3 BAR map that can be added to your order , item # 110659176040
If your current engine harness is in good condition , then I'll suggest going with option #3 , the PRO Platinum is just as powerful as the P2000 , the reason why is slightly cheaper is because it does not require a wiring loom since it plugs direct to the factory wiring harness .
Regards:Nelson S
The plug in pro will work regardless of the wiring harness. R32/R33 gtr gtst gts (have to swap two pins on gts). It has basically the same features as the P2000.
PM me sent too..
Cheers
Johno
PM me sent too..
Cheers
Johno
Hey Johno,
what are the main difference between the p2000 & the plug in pro? with the price difference i might aswell just get the better ecu??
let me know on that group buy thingo too.
the pro ecus have more options to suit the engine they are intended for. the sport 2000 can be configured on anything. but without knock control or afm inputs
but the pro is limited to that engine but accepts factory afm as a tuning input if needed and knock sensors to alert you of knock via engine light and can be configured to retard timing.
i would recomend it. (just did a haltech seminar on the weekend) download the ecu manager software from haltech and you can see the differances by loading the base maps for both the pro and sport ecu,s once loaded f4 shows all the options availabe to use
    • Have you tried another indicator stalk? Sometimes these go bad and cause issues.
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
