Up For Sale I Have A Few Items,
Contact: PM Me Or Post In Here, Will Check Most Days.
BRAND NEW! Gear And Handbrake Boots In Black Leather,
$20 ( I Have 2 Sets Of These)
R33 Fiberglass Grille,
Has Few Cracks So Selling Cheap,
$25
Wheel Spacers, Came Off My R33, (5mm)
$5 Bucks
HKS Turbo Timer,
Comes With Wiring Harness To Suit R33 (Uknown If It Suits Other Models)
$30
Items Without Photos, (But Can On Requested If Nessesary)
All In Good Condition,
Stock R33 Washer Bottle $15
Stock Series 1 Spoiler $50
Stock Series 1 Door Trims $40 (All 4)
Stock Series 1 Back Seats $30
Edited by DarkRB
https://www.sau.com.au/forums/topic/360289-lots-of-parts-new-and-used/
