Hey well,
Well just for inspection purposes I pulled out the plug from cylinder one. Looks pretty good to me but just wondering if it could be a tad on the lean side as it looks a little too clean. Plugs are more than 6000km old.
My main concern was detonation issues(my other ecu was reading crap load of ping at times, shit tune). Car has been on stock ecu for a fair while, only had the other one in there for a day.
Any input would be great.
These are copper plugs so I'll be changing these with the same ones on next oil change.
Cheers guys
https://www.sau.com.au/forums/topic/360290-how-does-my-spark-plug-look/
  • 2 months later...
Well lets bump this up just for comparison purposes. I recently had a few things put on my car(see the rb25 dyno thread). I put this stuff on the car and it was about a month or two before I got it all tuned. Before the tune I pulled the plugs and oil and what not to ensure everything went in fresh. The plugs came out looking just like above, nice and normal.
Anyway got the car back and the problems started. I put the exact same model plugs in, gapped appropriately. 2 of 6 failed after 300km. Look at them now. I just put a brand new set in there because of the misfires and shit that the car has been giving me.
I have no doubt in my mind that this tune is pouring fuel into my engine... I'm going to take it back and I expect not to pay anything more to have it looked at because this is a joke. I'll be chewing through spark plugs everytime I go to fill up a tank of fuel by the looks of it. I'm not impressed at all really and I kind of feel sick to the stomach. I thought I made the right choice in tuner but clearly the tune shows otherwise.
And to note, when the two plugs failed, I replaced them temporarily with the old plugs up in the OP. The picture you see if the old plug up in my original post, it was driven on for about 20km.
ok so others don't have to go looking for mods because you were too lazy to post them i have quoted your post from the dyno section.
you say that the pump was failing during the tune and that you fitted another pump. was that done after the dyno runs? if yes that that is your problem and your fault and not the tuners. your tune was done with a failing pump and you have gone and fitted a working pump which will now be supplying much more fuel (higher pressure) so the injectors will be pumping in extra fuel.
Got my car tuned but its going back soon.
Anyway its an R33 GTST Series 2 with the following:
Unopened RB25DET
HyperGear ATR43SS-2
3" JJR Bellmouth dump
HKS Hi Power Silent exhaust
Yellow jacket coils
NGK Copper plugs BCP7RES gapped to .7
Genuine HDI FMIC
Venom 5" body 100cpsi cat
Nismo 740cc injectors
Bosch 040(was failing during tune)
Nismo FPR
Greddy profec b spec 2
3" metal intake with Apexi power intake filter
Power FC tuned by Advan performance
Made 244rwkw on 11.4psi. That is with the boost controller set to 100%. That is as much as we can get out of it. With about 15psi, we should see about 270rwkw and 17psi about 280rwkw. 20psi should see 300rwkw on regular fuel pump.
Ive fitted a GTR fuel pump in there to fix the fuel pump issues. Probably will swap that with a brand new 040 pump or run it as a lift into a surge tank. Last printed dyno shows about 238rwkw on 11psi, should have printed the previous runs :P
When I took the car to the tuner I had no problems with the car. The tuner said it will take him about a day to set everything up and test everything on the car before he tunes. He had to install my new injectors and setup the fuel pressure on the regulator, he asked me what fuel pump I had and I said a 040 and he said ok its all setup correctly to be run in on the dyno. When he was about to start the tune(I was not there at this time) he said the AFR looked strange at low RPM. He said it may be due to surging of the turbo at low RPM and that is nothing to worry about. After the tune was complete he said he is happy with the power it made at the set boost but said it can do with more boost. I took it home the next day and the pump failed. I did not know. He said the fuel pressure was good. The pump was priming. If the pump was failing he should have picked up on it. That is like saying one of my piston rings is worn and I didn't tell him. I payed him $800 to check my cars health and do a tune. He made me pay him to regap my plugs. He made me pay him to fix my PCV valve. He made me pay him to test my fuel. Its a f**king joke that anyone would think its my fault. How was I to know? I drove this car for 8 months without a single fuel related issue. The only real issue was my coils failing on me which I fixed my self. It was only after I told him the pump failed AFTER the tune that he did suspect the pump was failing during the tune.
When you go to a mechanic to fix a problem on your car, its up to them to find the problem based on your input. I told him what the car had, that it was fine. He ran the car on the dyno and say the poor AFR. He could have told me that he suspected the pump is going or it felt lazy rather than continue tuning and take my money.
Another guy on here had his car tuned, payed for it, took it home and it was running rich as shit. He then realized he had something unplugged(which he unplugged him self). He took it back to the tuner and the tuner fixed up the fuel map for free even though this was the car owners fault. I hope for my sake that this tuner will not take me for more money.
Edited by SargeRX8
the pump may have been failing by a small enough amount to not seem too bad (lets say 25% down) since all he has to work off is injector rates and every car will run different injector rates with similar mods. once tuned at that rate if a fully operational fuel pump put in it will run rich as hell (since it has just started adding in 25% more fuel). that is not the tuners fault in my opinion.
as for your tuner charging you to do work, that isn't that unreasonable is it? they are doing work, why shouldn't they get paid for it. if it doesn't solve the problem then they can't be blamed for that if they honestly thought it was going to help. often with car problems there can be many different causes so you just have to go through each possibility until it is fixed. sometimes you might get it first go, other times it might take you a day of mucking around. some people will be kind enough to fix stuff for free, especially if it doesn't take them much time to fix or they made a reasonable amount of money off the initial work.
the fact remains though, new pump is the cause of the running rich. had the pump continued working for a year then the tune would've been fine. it essentially is no different to a tune being out because a bigger turbo was fitted.
Do you think the fix could be as simple as adjusting the fuel pressure? If the pressure is set to 43%, how much impact would a fully operational pump have on pressure?
I can understand what you are saying but if I have to pay again for a tune and be out of the car for a week, its about harsh on me, isn't it? I'll be going there tomorrow showing them the plugs and seeing what can be done.
it could be a case of simply dropping the fuel pressure, however it will come down to whether it is rich all over the tune or just up high (which is most likely since the fuel required at low load is bugger all so even a dying pump shouldn't be leaning out at idle). my guess is that only the upper end of the tune will need to be altered and even this shouldn't require too much work, depending on whether they tune with the hand controller or with pc software
and yes i agree with the fact that it isn't really fair if you have to pay for a second tune.
Hey Sarge i hav to agree 110% with everything mad082 has said about the fuel pump and mechanics in general. Its a process of trial and error in alot of cases. Also agree with him in saying about the fuel pump throwing the tune. But i also know exactly how u feel about paying again.
Im sure if u ask NICELY that advan will help u out in rechecking/setting the AFR's across the board.
Just be sure to be friendly. Don't accuse them and get them off gaurd.
Let us know how u go today.
As polite and kind as I could be, he wants a couple hundred and the whole day to adjust the fuel pressure and tidy the tune on dyno... Is this right?
time frame wise it seems reasonable since i'm guessing that just dropping the pressure won't be enough since you still have to maintain a certain amount of pressure, so a lot of it will be redoing the actual tune. money wise i'd compare how much he wants to how much it cost for the initial tune. if it is much lower then i'd say it's reasonable. if it's clsoe to the same cost then possibly not
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
