Write an official letter to the manager or whomever is in charge and send it via registered post that they have to sign. Clearly state in a very proffesional manner what happened including time, location etc. Every detail you can basically. Also mention the witness. Let him know that you require a response within 7 working days and that you want to sort this matter otherwise you will be forced to take it to consumer affairs.
Be as proffesional as you can be. If you sound like some one that is angry they wont take it seriously. If you sound like some one that can present them self well you will get a response.
Good luck.
How can they send some one out to start un-plugging things they nothing about??
Thats like me doing the wiring in a friends house or hooking up a new gas appliance then it all going tits up and me saying oh well you should of got some one who knows what they are doing sorry.
Clearly in his own words he aint a mechanic so then why is he acting as one messing with cars??...
The inspector does admit disconnecting but says he's unable to help as he's not a mechanic.
Call fair trading if the guy can't produce a mechanics qualification then it should be pretty much an open and shut case
I can't belive this happened
Definitely call fair trading, and the free legal hotlines (cant remember what they're called atm).
Also post up some pics so we can see what's been undone. Someone on here may be able to help identify what has happened.
The inspector does admit disconnecting but says he's unable to help as he's not a mechanic. What really bothered me was that he left the car after he couldn't get it running again (said its not his fault)...
Judge Judy would have a field day with this. Our legals should be no less lenient!
How can State-roads hire a monkey and then dress him up as a mechanic? > Grenade with a loose pin!
I know that you want to take him / them to court...
But check your main fuses dude... It may be 20 bucks to fix the car versus 2 grand in fort costs :P
That's actually a really sensible suggestion...
Yeah sounds good and hopefully works...
But i would still be getting in touch with trading std's or the onbudsman about the fact that a un-qualified mechanic works there and is going messing with peoples cars/possibly lifes...
How does someone whos not a mechanic carry out a mechanical inspection?
Which means that before State Roads, RACQ, NRMA, RACV yaddayadda ever touches your car, you need to demand that he show you his ticket? :whistling:
That sucks man but I've used state roads several times as a buyer and I can't overstate what a good job they did. I would have purchased some absolute lemons if it wasn't for them.
I guess each company will always have an instance of bad customer service.
Edited by ras1983
Yes...too sensible if you ask me :ph34r:
I'm concerned, Birds.
I anticipate an attack is imminent. We must fortify our avatars with pictures of naked women covered in Skittles to distract him. Also, if he works in a strict office workplace environment he could possibly lose his job for having such content pop up, thus cutting off his financing... unless the sith have been funding his operation.
In which case, I think we should call the ghostbusters... or that guy in the motorbike who's being reallyreally loud outside and i'm waiting for "REEERRRR REEEER REEERRRR *THUD*"
Okay I'm getting delirious... good night :D
Furthermore; best car inspector I've had looked at the car, laughed, begged me not to make him inspect it, took his money and left.
Apparently that's the technical way of saying "it's shit".
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
