It shields heat...
Not hugely important but if your running a inboxed POD filter you would be getting alotore hot air sucked in from the engine bay
haha thanks!
But seriously is there a problem with the wire not being connected? Should i bolt it to somewhere else? Is it actually an earth?
I;m more worried about the wire not being connected causing problems.
Thanks for the help so far.
I know mines not connected as I have an aftermarket du pipe and the heatshield wouldnt fit
It hasn't caused any problems
But I would be interested to know what it's grounding
haha, when i read the title of the thread i wondered if it was the same 'wire' that confused me, and it was!
i was missing a heat shield, it had disappeared (i think) when the turbo back exhaust was installed along with the dump pipe shield. not that it matters cuz it wouldn't have fitted the new pipe anyway,
i attached it to a bracket which held the original heat shield. i imagine its an earthing wire.
Yea i' dont wanna remove it, Id much rather connect it then take it off afterall it wouldnt be there if it wasnt important. Its just that it seems like the end that isnt attached should be attached to something immportant (i know the heatshield) but the end that is cconnected just seems to be earther on the chassis?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
