i'm in melbourne: full comp. for an r32 gtst for me at 18 years old from just cars. $3200 + $1800 excess... this would last for 7 years (as they drop when you hit 25) ... so 7 years of over 3 grand = 21+ thousand ****ing dollars = more than the cars worth = **** that... rather buy 2.5 skylines ha ha ha
wtf!!! thats heaps man!!
looks like i'm going 3rd- party next year..
I have a R33 GTST and its $3000 for full comp insurance. I didn't have any previous insurance history. Ring Famous Classic Car Insurance.
Just a thought. I had a look at the comprehensive policy for Famous Classic Car Insurance and chose against it because although they will insure your car at an agreed value, it says in the policy that if your car gets stolen or is damaged beyond repair, they will pay you either the "agreed value" or the "current market value" WHICHEVER IS LESS.
A nasty trap that some insurance companies lay.
Till you hit a BMW and have to pay for the damages........
Look at it this way.
He is either a very careful driver, never speeds, never drag races, and is not going to smash up his car. If that is that case he does not need any insurance.
If he is a bit of a hoon, planning on hotting up his car and having fun in it, he is almost a certainty for a prang. Insurance companies know this too well, and either will not insure him. or make sure they are going to be very well rewarded for taking the risk.
If he does fork out the big dollars and writes it off, expect the insurance company to do everything they can to get out of paying up. This is easy if he is drunk, breaks the law in any way, or has modified his car. Read the fine print on the policy and be surprised at what it actually says.
Best bet is to just put five grand away in the bank. At least you know the bank are not going to tell you to piss off when you go to draw it out again.
Another way to look at it is, get five of your mates and each put up four grand. The first one to write off his car gets the lot. Would you trust five of your mates never to have an accident ? Why not ?
Most 3rd party property + fire and theft ONLY cover fire and theft upto a certain amount ($5000 or so i think) so while it does not leave you completely open to some low life scum car thief to screw u over, $5000 is by no means a new R33/R32/any high performance sports car.
very good analogy! its basically how the system works... and why insurance premiums are so high. Why drivers who have had 10 years driving experience and no accidents are still paying well over $1000 for the privelege, then you have to wonder though. Effectively we're subsidising those that do have crashes. And they wonder why when a young guy on here has an "incident" some of the older guys jump on their case.
and like nmcmahon83 correctly says.. theft on a 3rd party policy will NOT cover full value of the car.
I am an old fart, I admit it, but I was young once, and know exactly how it is. And I am not trying to put anyone down.
The insurance companies are a business with only one thing in mind, to make money for themselves and their shareholders. They are not there to help you, or perform charity work.
Young drivers are a higher risk than old farts. That is a fact. It is also a fact that ANYONE is more likely to prang a high powered car than an underpowered slug.
So saying I am young, and have a high powered car, where can I get cheap insurance, is really a bit of a problem.
If I was an insurance shark, I would say sure, sign here young fella. Then when you prang. Sorry buddy, read the fine print you are not covered, read paragraph xxx clause yyy.
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
    • If you want the screaming "weeeee" sound, just let the gasket between the exhaust manifold and the turbo break a little. It'll go "weeeeeeeeeeeeeeeeeeeeeee" everytime its on boost...
