  • Replies 61
Posted Images
hi all,
thanks for ur support ........ just an update for those who want to look at the pictures of F**KED Bodykit................ I can't upload any pics due to my car being fixed at JETSPEED IN CLAYTON......... i have to buy a new bodykit from JETSPEED as the guy told me that it will cost me more to repair and fix the kit ,,,,,,,,, so he will take the bodykit off my car and i will upload the pictures of side skirts and rear bar and front bar............ but i can't upload the pictures of spoiler as guy at JETSPEED will fix it for me.................... i want to bash this guy (FIRTY2---his SAU username) but he is too young (21).............. feel sorry for him..........
is there any possibility aside from his shit job, that the kit you had was shit i mean if he had to lengthen the side skirts just to fit the blame may not lie solely with him.
get what ya pay for.
To ALR33X,
mate , take your car to him and tell him to paint your plastic spoiler...........then you will see yourself (that what he did to my geniune (plastic) series 2 spoiler......... you can say anything while sitting at your home on your computer but be realistic......... i am not idiot who will spend $1500 on shit fibreglass kit ...................... if he knows anything about bodykits then i was not discussing these things with you..........pinch.gif
taken from thread.
"Hey guys thought I'd share with you some work i'm currently undertaking for a fellow SAU member
Car: R33
Body Kit: Veilside Rear Bar, Unknown skirts, Series 2 Wing.
Being trusty fiberglass its had to be modified; the skirts have been extended by 2cms and the rear bar has been cut into 3 pieces and shut back together.
Pics are of work so far and will upload more as I get it done. "
sounds like you bought a shit kit, gave it to an unknown and expected a miracle.
the poor man pays twice sir.
taken from thread.
Car: R33
That sounded like alot of work done to the body kit.
Although I hate to say it too, the body kit was prepared and worked in a worst possible way. So either it has to be a a very bad quality, or the person responsible didn't have the experience of body kits (Genuine or replicas).
You could really have gone to a reputable place if you weren't sure of the quality of the body kit.
Sorry to hear about your incident. Hope you learn from this and get a good outcome.
lol $1500 is a cheap kit and $900 is cheap for a fit/paint
i had my front bar fitted PERFECTY (note correct use of caps lock) by micolour and that alone was a $1000 job
quit whinging
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
