As the title says, I got a 98 R34 GTT 5spd coupe which I need to swap for an auto. Its not perfect but in the last 12 months Ive probably spent $3K on things like 100K service, dump, front, tie rod ends, cat, ebc and hd clutch. If I was to sell it for $$$ I'd probably ask around $17K as a starting figure.
My left knee (clutch!) and lower back are stuffed but refuse to drive a falcodore! Truth be told I'm probably 12 months away from not being able to change gear on a regular basis.
Looking for either a another GTT coupe or a S2 RWD C34 stagea. Given Im downgrading to an auto the cars in question would have to be pretty good (paint, low kms etc) to be a straight swap. Especially the stagea - Ive seen a lot for sale recently at around $13-$14K! Mind you, I'm dont need the cash so if you reckon ur auto is good enough for a straight swap for a manual, bring it on!
If interested send me an sms on 0432917947
https://www.sau.com.au/forums/topic/360341-sa-r34-gtt-manual-for-swap/
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
