Hey can i please be helped with s13 NA Modification Tuning
URAS Type NS-S Exhuast system 60mm pipe with 100mm cannon.
HKS Step 1 cams....256 degrees and 10.5mm cam lift and 111 degrees valve timing ORRRR 264 degrees with 10.5mm cam lift and 111 degrees valve timing
HKS SUPER header II extractors?
How much power would i gain at the wheels? 45KW?
Edited by WanganMidnight
https://www.sau.com.au/forums/topic/360355-silvia-non-turbo-mods/
I'd probably guess an overall 20-30rwkw gain... at the end of the day its a 2L motor....
and if you go too big on the exhaust u loose back pressure. loose too much of it and the car becomes even more sluggish in lower revs...
.......soo $2000 worth of mods and id gain 20KW? how is that possible?
lol... yeh mate... NATURALLY ASPIRATED....
in the turbo world, you can buy a t-piece boost controller for $20... take the boost up an extra 5-7psi and get 40kw+ ....
most people dont bother doing up small n/a engines because the gains arent worth the $$....
How about dropping a turbo motor in there or adding a turbo to the current motor (assuming ur not on ur p's) and then getting urself an extra 50-60kw+ for 2000
I'm on my P's, how much would a SR20DET HALFCUT + id have to convert to manual cost.....do you know anyone reliable who sells them?
because that's what we gain with those mods on an NA supra, so its totally not worth it.. keep it stock, or get a turbo..
but if you wanna do up the NA, go read up on some threads, i would be sure the same mods on RB engines would apply on your SR20, or ca18, which is it?
10-15rwkw, if you're lucky.
You're going to make a max of about 95rwkw if everything works well together and the ecu doesn't have a cry
If you go bigger cams, nistune it and up the red line plus tune (so another 1100) you might get another 5-10rwkw on top of that
So basically 3k to get you to about 105rwkw, 110rwkw if you have an s14de as the compressions a bit higher.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
