hey guys my gtr 32 is chugging when goin about 80 kms it only does it in 4wd mode
is it because car too low ??
what could it be its deff in drive chain not engine weird
please help if ya can
diff size tyres from front to back .. but it has always done it a bit and got worse now only in 4wd really annoying
but i had squeak in suspension checked and they said it sitting on bump stops at front
fluids are fine i repalced some copper washes at attessa pump because was leaking .
whats best thing to do ?
A problem right there (not *the* problem though I don't think), ATTESSA expects same size tyres all around (best to stick to same brand).. even with the same brand tread difference between front and back can trip ATTESSA up. ATTESSA wasn't meant to be run fulltime, even if it's a tiny bit from the tyre difference the damage to the transfer case (clutch packs in particular) might already be done.
Even when I had 235/45/17's all around, with the new ones on the front and worn ones on the back it was enough of a difference to produce this effect.
What rims and tyres are you running currently?
Shouldn't ever do it in 2WD mode. As per the several thousand other threads that discuss this problem, the ATTESSA thinks the rear wheels are slipping, because they are smaller rolling diameter than the fronts, and therefore rotate faster.
I am still at a loss as to how many times we have to tell AWD owners to match the front and rear wheel / tyre sizes.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
