I ment these clips as Hel use in the GTR kits. Because of the factory hard lines coming out of the caliper on the GTR the rest of the line doesn't really need to be secured much. So you could also use a ziptie that is loose.
http://www.skylinesa...brake-line-kit/
I don't believe that the hardlines are very strong, they are meant to go from a to b with b being a fitting, not to a long length of waggly braided hose which tugs and pulls as the steering mechanism moves etc and suspension goes up and down.
Just me 2 pence, 'cos I was thinking of just doing that and when I got down and started doing it I could see it was a piss poor engineering solution and was gonna stress the flare nut going into the Brembo, instead of a braket/fitting taking all the loads/stress.
So that is why I got the HEL line instead. :)
  • 3 weeks later...
The Brembos are 10 x 1mm thread same as sumito...Asian standard or whatever it is. :)
The bolts that hold the Brembos to the car are a coarser thread than the Sumitos though.
Should I just bring one brembo caliper to my hardware store and see which bolt fit in?
